Old 05-31-2016, 08:35 PM   #31
mike.t's Avatar
The 1/4" I was referring to is just behind where you would connect the hose.
Thanks for your help
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 06-11-2016, 09:01 AM   #32
simple fix
the painter tape marked the original intact line
lines cut,l crossed, then seateched together
myhorse is offline   Reply With Quote
Old 07-31-2016, 09:39 PM   #33
viperdave's Avatar
Originally Posted by myhorse View Post
simple fix
Add mine to the list of reversed lines for the flush. I used the solution that myhorse showed. Costs under $10 and literally takes 4 minutes. Thanks to all for posting their fixes and paving the way for the rest of us to make things easier. Sorry AWF1945 for you back troubles. I looked at the check value in the bathroom and don't know how you even got in there for a fix.
2016 Dynamax DX3
viperdave is offline   Reply With Quote
Old 08-01-2016, 08:24 AM   #34
GM
bclemens's Avatar
At my previous division, it was always the valve installed wrong so I had them check here (no pun intended) and they all looked fine....but this would explain it. Should be testing that anyway so no matter what the cause it gets caught. Did that at the previous division and then found out they were winterizing everything, but that...which caused its own issue. Murphy's law.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 08-01-2016, 09:14 AM   #35
AWF1945's Avatar
I like myhorse fix too. Sometimes its better to step back and think about solutions rather than just jumping in. My fix wasn't really that bad, if you've played the game twister... lol
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
Old 08-01-2016, 10:04 AM   #36
viperdave's Avatar
Somebody always has to be first and dive in and actually diagnose the problem which you did - Thank You. Once the problem is diagnosed, other people that are a step behind can actually focus on other fixes. You went right to the core of the problem, maybe not the easiest work around.
I'm fairly nimble and only considered changing the lines at the valve for .5 seconds....lol
2016 Dynamax DX3
black, black tank, black tank flush, tank
