Old 02-19-2016, 04:16 PM   #1
AWF1945's Avatar
Black Tank Flush
The flush doesn't work. Looks like it plumbed wrong unless I'm missing something. Blue pex goes from flush inlet up into coach up through floor, back down into black tank. ? Is there a check valve somewhere? If so, it may be installed backwards .. water does not flow at all..
ID:	99927   Click image for larger version
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
Old 02-19-2016, 04:25 PM   #2
fonzie's Avatar
Yes there should be a back flow preventer somewhere in the coach usually in the bathroom vanity...
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 02-19-2016, 04:31 PM   #3
AWF1945's Avatar
Thanks for the quick response. . I did find it.. my guess is, the lines are reversed. Wonder does it have to be on that upward position to work..
Thanks for taking the time and send a picture.
Old 02-19-2016, 04:36 PM   #4
fonzie's Avatar
First I would tap it with the handle of a screwdriver to see if stuck and try black flush again. If not working then I would try reversing connections. On occasion people reported that the actual nozzle in the black tank was filled with construction debris (sawdust) thus preventing working properly.....good luck.
There are many threads on subject....
https://www.google.ca/search?q=black...rqHYaneqG8j5AM
Fonzie
Old 02-19-2016, 04:43 PM   #5
GM
bclemens's Avatar
Yes...the check valve has to be above the flood line (aka above the toilet drain) per code.
PLEASE do not send questions via Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 02-19-2016, 05:33 PM   #6
AWF1945's Avatar
I removed the check valve it appears to be free from debris. My guess is as suspected, the lines are backwards. I removed the line from the black tank itself and nothing.
Im shorthanded today. When I get it back home I'll have a partner bolw compressed air through the line with the valve removed and see whats going on.
The valve has to sit as shown in picture in order for it to function properly.
Old 02-19-2016, 05:56 PM   #7
Usually the inlet (from your hose) is at the bottom and the outlet (to your tank flush) is on the side. See pic on post #30 here:
http://www.irv2.com/forums/f112/tip-...-270158-3.html
They probably come up through the same hole and the guy could have easily got them mixed up when he put the valve on.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
Old 02-19-2016, 07:04 PM   #8
same same
Ive had the same issue with our DX3. To date I have not explored the issue.
Looking forward to your conclusion to help me troubleshoot ours. Please keep us posted......Bob
dmax36 is offline   Reply With Quote
Old 02-19-2016, 07:33 PM   #9
bubbles's Avatar
I only post this as a reference for a typical black tank clean out system installed at the factory.
Name:	black tank cleanout1.jpg
Old 02-19-2016, 08:29 PM   #10
AWF1945's Avatar
I will get to the bottom of it and let you know.. pretty straight forward I would think. Either the lines are reversed at check valve, or bad check valve. Kinda of a pain to get to, but could be worse. ;-)
black, black tank, black tank flush, tank
