02-04-2019, 08:38 AM
#21
The product that started this off topic rant was Happy Camper. It is septic tank friendly so this is another unwarranted comment.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
02-04-2019, 09:09 AM
#22
But how do these products affect tire pressure??? :roflback:
2016 Dynamax DX3 - Big Blue
02-04-2019, 10:22 AM
#23
I heard from a dubious source that the bacteria convert human waste into helium. Result is less weight on the tires, hence one can run a lower pressure for a smoother ride.
2017 Dynamax REV 24RB
2018 Ford F-150
02-04-2019, 12:09 PM
#24
Just as confused as you
It also creates methane gas, so never use a candle for a light source when you dump the tank at night.
Richard & Jill
02-04-2019, 08:00 PM
#25
That would make a good YouTube video.
2018 Ford F-150
02-05-2019, 01:52 AM
#26
Consumer of Space
Or smoke a cigar while dumping septic, as the Grizwalds have shown.
2018 Dynamax Force HD 37BH
02-05-2019, 02:52 PM
#27
Hahah you guys never disappoint!
02-05-2019, 05:06 PM
#28
We try.
To disappoint that is.
Richard & Jill
02-05-2019, 05:27 PM
#29
Originally Posted by scrapper
we try.
02-11-2019, 07:18 PM
#30
I know I'm going to get blasted for this but. I use bleach and a heavy squirt of dawn. About once a week. But my park model stays I. The same spot all the time. Yes I do use the black tank. Not directly in the sewer.
02-11-2019, 07:23 PM
#31
Fixes to black tank stink
We had and resolved this problem twice. Once in TT and once in 5th wheel. In one case, went on roof and found toilet roof vent had been closed by moron who washed the rig for us. We opened it and problem solved.
In the other case, we read that gunk can build up in parts of the toilet and black tank that don't normally get filled with water to wash it out. So we filled it up with water past the brim...all the way up into the toilet and let set for 24 hours after adding some dawn to loosen all that stuff causing odor. We then drained black tank and wa..la..no more odor!!
Hope this helps!
02-11-2019, 08:18 PM
#32
We use the Geo method - once scoop of Gain laundry detergent and one scoop of Water King Softener. We started out with these in just the black tank but now use this method in the gray and galley tanks, as well.
https://sites.google.com/site/cbruni/
2008 Wildcat 29RLS
2016 Chevy Silverado 2500 HD
4x4 z71 Crew Cab Duramax/Allison
02-11-2019, 08:57 PM
#33
We had the same problem in our 5th wheel, changed the air admittance valves/vents...fixed! The valve was barely allowing any air back into the rig, but any pressure built up the tanks would force the "gas" into the rig.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
02-12-2019, 07:39 AM
#34
Black Tank Smell
I bought a FR travel trailer last year and it came with a sample of a tank deodorizer. I think it was "Three in One."It fizzes and is a toilet bowl cleaner and then you flush and it becomes the tank deodorizer. I've never used a better one than this one, so I ordered a supply of it.
02-14-2019, 09:03 PM
#35
2018 Isata 5 30FW
Banjo Bill, I have had the same problem. I tried timing the flush, using good oderiser and plenty of water as Brian has recommended. I haven't checked the 360 vent yet. I still have the smell. I open the window and then close the door quickly so the smell stays in the bathroom. After a while I will go back in and close the window. Annoying...
02-16-2019, 07:40 AM
#37
2018 Isata 5 30FW
Thank you !
