Old 07-04-2017, 06:45 AM   #21
Fastedy is offline   Reply With Quote
Old 07-07-2017, 09:37 PM   #22
WFD
I sent an email to Dometic, next day got a reply offering to send me the white ones. Sent them my shipping info and they emailed right back saying it was shipped and should be here in 4-6 business days! Thanks folks!
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 07-08-2017, 09:29 AM   #23
tuckerdog1's Avatar
Maybe a little long winded, but these are the swap out directions I sent to another member.
I should have taken pics. But it's all behind me now.
There are two screws located toward the front of the cover. They are recessed pretty deep. The holes they are in, almost look like the recesses the blue leds are in. Anyway, unscrew & the cover will come away. There is a wire bundle with those plug in connections. Only one of the connections is keeping the unit connected to the fridge. That's the one off by itself, near the on/off switch. Unplug that one and you can get the unit away where it's easy to work on. The blue & white light circuit boards are a "little" different, but are the same shape. So they swap out cleanly. Unplug the two remaining wire connector plugs on the blue light board. Then the blue light board is ready for removal. There are 3 plastic hook tabs holding it in place. I hate these things, because it seems like one or more always break. I 1st tried the center tab, but was getting nowhere. Then tried one of the tabs to the side. It let loose real easy, and after that one came loose, the rest were super easy. Then it's just snap the new board in place, put the plugs back and reassemble. Be sure the on/off switch is mounted to the front of it's "spot". Don't want the fridge door pushing it back into a void.
Tuckerdog1
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
If you don't punish your children, life will.
tuckerdog1 is offline   Reply With Quote
Old 07-13-2017, 09:54 AM   #24
Still replacing Blue Lights
Just received the "white lights" to replace the "blue" on my Dometic DMR702 'fridge after calling Dometic 574-294-2511 then selecting 1; 3; 2
(believe) and speaking to a nice lady who said she would send the "white" to replace the "blue". It is a Printed Circuit card with LED lites light on it.
Hope this helps.
lengercce is offline   Reply With Quote
Old 07-13-2017, 09:29 PM   #25
WFD
Mine arrived today and I immediately replaced...easy thanks to tuckerdog's tips...Much better lighting now with the white....that blue light was not pleasant. Thanks folks!
Old 08-17-2017, 04:39 PM   #26
PARADOX-SEV's Avatar
Got the new white led's today. Less than 10 minutes to swap them out.
PARADOX-SEV is offline   Reply With Quote
Old 01-03-2022, 05:11 PM   #27
We had this same issue, and were able to order another one and it took 15 mins to swap out!
It was so hard to see our food when it was blue.
Here is a link to get online, they were hard to find.
you can find in a tutorial to see it here:
hope that helps! Happy camping.
okrighton is offline   Reply With Quote
Old 01-03-2022, 05:39 PM   #28
Welcome to the forum, I see it is your 1st post!
Just wanted to point out you commented on a thread that is going on 5 years old since its last post.
You may want to visit the forum 101 section of this site.
It might help you get the hang of forum posting.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
fridge, light
