Old 07-04-2016, 11:46 AM   #1
viperdave's Avatar
brake controller harness DX3??
Some freightliner forums say the harness is under the dash, some say it is under the cab drivers side. I bought the DirecLink brake controller that uses the interior brake control harness. Has anyone had luck finding it behind the dash. The second pic is the harness that is under the cab.
2016 Dynamax DX3
viperdave is offline   Reply With Quote
Old 07-04-2016, 05:56 PM   #2
FOURWHL's Avatar
Second pic is your harness. Need to feed it through the firewall. I used one of the knockouts in the plastic are where the air lines are run.
FOURWHL is online now   Reply With Quote
Old 07-04-2016, 08:00 PM   #3
viperdave's Avatar
Thank you! I'll leave it all apart to run the wires and wire in Direclink. Also replacing the cigarette lighter with a wired in dual usb charger.
2016 Dynamax DX3
Old 07-04-2016, 09:59 PM   #4
You should enough loom to run it under the cab, through two harness holders and then into the firewall.
Mike
2016 Force HD
Mike
2016 Force HD 36
BLK-9 is offline   Reply With Quote
Old 07-11-2016, 04:03 PM   #5
viperdave's Avatar
got the wires in but I have another question. The harness has White, blue, red and orange wires. My controller has white, blue, red and black wires. Which to which???
Mike
2016 Force HD
2016 Dynamax DX3
Old 07-11-2016, 04:17 PM   #6
viperdave's Avatar
DirecLink is the controller I bought. Their wiring harness wants:
Black = 12V
Red = Brake switch
White = Ground
Blue = Trailer brakes
2016 Dynamax DX3
Old 07-11-2016, 04:21 PM   #7
FOURWHL's Avatar
Your controller should have instructions which tell you which signal goes to which wires.
I would highly suggest getting a multi meter and testing the harness in the truck for ground, 12V, brake (you'll see 12V when pressing the brake) and the last can be assumed to go to the trailer.
2016 Dynamax DX3 - Big Blue
Old 07-11-2016, 06:08 PM   #8
viperdave's Avatar
I posted the controllers requirements above, I was just hoping that you guys remembered what the Freightliners wiring decode was. I'll just check them with the multimeter. I had it out today replacing the cigarette lighter with a dual usb charger.
2016 Dynamax DX3
Old 07-11-2016, 07:21 PM   #9
FOURWHL's Avatar
Ha didn't realize that was you ... I'm losing it
Iirc red was brake and blue went to the trailer which leaves white and orange for power, but I'd definitely verify yourself
Old 07-11-2016, 08:16 PM   #10
viperdave's Avatar
Thanks, I'll give it a check. The DirecLink is quite expensive so it will be interesting if it that much nicer than standard brake controllers.
2016 Dynamax DX3
brake control, controller, brakes
