04-19-2019, 07:52 PM
#21
And the saga continues.
Dynamax does not have the required parts in stock and only provided a link to Amazon for the part.
I am in field working so DW spent most of day looking for part. Found at a trailer supplier in Fargo, ND 100 miles away one way. DW does not have a way to go get the part. Had to send a runner from our work site to go get it. Managed to get there before closing and returned to work site.
200 mile round trip 4 hours pay for the runner. I only have this weekend to get the slide fixed. It is rough to sleep on the floor.
But, we are "having fun" here in ND.
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
04-19-2019, 08:21 PM
#22
Now that's being positive!! And DW dug in when the chips were down. Doesn't get any better than that!
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
04-19-2019, 08:33 PM
#23
May not help... there are places that build cables. I’m not sure in North Dakota, but I bet a google search would help. Depending on the crimp and type you need. Some utility type electrical crimpers would certainly be large enough. Some hardware stores carry aluminum sleeves and maybe stops if that’s the type you need. Looks like maybe 1/4” wire” and maybe that won’t be impossible to find.
https://www.google.com/search?client...60.pTMPc7yl3Es
2017 Puma 297RLSS
04-23-2019, 09:10 PM
#24
Finally fixed!
Repaired broken cable slide. Had to replace two cables and build new mount for the forward cable pulleys. Previous post showed the carnage.
Here is the new version of the cable system mounts.
04-23-2019, 09:21 PM
#25
Broken slideout cable on 2016 Force 37BH
Originally Posted by KRedburn
Finally fixed!
Attachment 202662
Looks good. I ain’t picking...cause I don’t know, but the lowest cable looks a bit slacked....in case it matters.
One thing about it....if you need a place to attach a winch line....that will hold. [emoji6]
2017 Puma 297RLSS
04-23-2019, 10:00 PM
#26
Question, how did you access those top pulleys that are buried? And, Btw.. nice job. Glad your up and running.
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
04-24-2019, 03:15 AM
#27
Glad you were able to get it fixed, my question is what was special about that cable? Big box stores sell cable. I had a cable slide once, and I was always adjusting that chain. Don't like them at all. Glad you and your wife kept a positive attitude....now get a good night sleep.
Coachmen M/H
Concord
2018 / 300 DSC
04-24-2019, 03:39 AM
#28
Nice job!
Cindy & Walt
2018 DX3 36FK
2015 JKHR - toad
04-24-2019, 05:49 AM
#29
Glad you are all fixed up, great job, thanks for the information.
Joe & Debbie
2017 Dynamax DX3 37BH
Toad: 2020 Ford F-150
04-24-2019, 07:35 AM
#30
Wasn't completely adjusted when photo was taken
04-24-2019, 07:54 AM
#31
the cables were not broken but the lower pulley assembly on the wall ripped out. They were badly frayed. We cut the cable and used it to draw a string thru the hidden pulleys then pulled the new cable in.
As for what is special, the cable end that connects to the slide flanges has a button swedged onto the cable. If you have the proper tool to do this and the button fitting then no problem. To properly clamp the cable with a crimp sleeve the tool is around 350.00. Fortunately we were able to borrow one.
04-24-2019, 08:04 AM
#32
Commercial Member
Looks good. Our guys pulled one out...but when we reviewed, it was because the batteries were fully charged (as they should be) and they held the button just a tad long (not saying you did this...but that's what they told me). On review, it almost seems like the guys that build that cable slide, assume the voltage won't be topped out so they add a little bit to the motor torque to compensate. We have some heavy gauge aluminum and backer in there and some good sized fasteners. But that motor is crazy strong.
04-24-2019, 08:19 AM
#33
your heavy guage aluminum would be great if the lag bolts are connected to it. On mine only one bolt was into the aluminum. All others where in sidewall core (foam) Take a closer look at the carnage picture. We were connected to shore power when this happened. I agree, that motor has some crazy torque!
Took awhile to repair due to our location but it is fixed so we're good to go!
04-24-2019, 11:25 AM
#34
Very nice work!
2016 Dynamax DX3 - Big Blue
04-24-2019, 11:36 AM
#35
Nice job.. I don't hold my switch after it's in or out. I let off of it. I don't guess it has set stops like front slide..
