Old 11-17-2019, 03:39 PM   #1
Burnt Bird to BIM Retrofit 2017 XL
My Bird melted at the ground terminal a few weeks ago so I decided to upgrade to the Precision Circuits BIM 225. Brian was kind enough to provide a wiring diagram . BIM 225 and diode was ordered from Danielle at Dynamax parts.
Installation was straight forward. Below are a couple of best practices I ran into.
1. Power Glide Slide power cable needs to be connected to power on (House Side)
2. P3 connecter with wires that were on old solenoid was hooked up to Buss Bar on (Chassis Side)
3. Buss Bar was needed because chassis power cable from solenoid had no free play to run to BIM.
4. Bird and Solenoid had to be removed to make room for Buss Bar
5. MP Micro circuit breaker on (Chassis Side) is not used as far as I can tell. No voltage coming in.
6. ABS battery switch on dash does not light up red like it did before. Not sure if it is working or not. That is the purpose of the light green connection on right side of BIM
2017 Dynaquest 37XL RB
Worm43 is offline   Reply With Quote
