10-12-2017, 11:09 PM
Cabinets
The cabinets over the sofas, the ones that lift up vs swing out, are they supposed to stay up themselves? None of mine do and it is a pain to try to hold them open while your trying to load them or get things out.
10-13-2017, 02:46 AM
I only have one cabinet door like that on my Isata 3, but I installed an arm to hold the door open while I load or unload the cabinet.
Something like the attached, but I found it at my local hardware store.
https://www.amazon.com/gp/aw/d/B01N2...JkL&ref=plSrch
2021 Isata 5 30FW
2022 Ford Ranger Tremor 4x4
(Previously owned a 2017 Isata 3 24FW)
10-13-2017, 03:42 AM
You can purchase cabinet struts, they aren't difficult to install.
05 Ram 3500 Cummins Dually
14 8280WS Rockwood Sig. Ultra Lite
Prodigy 3 brake Controller
TST 507 TPMS
2017 = 30 nights / 2018 = 7 nights
10-13-2017, 06:16 AM
The simplest way to hold up the cabinet door is with a spring in compression that gets straight when the door is open.
To close simply tap the spring out of line and the door closes.
RV or boat stores , cheap too!
Stainless Steel Hatch Lift ...$7.84
iboats.com
10-13-2017, 06:43 AM
Replace the hinges. They have a thin rivet in them, it snaps off and will not hold up the door anymore. I replaced about three.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
10-13-2017, 07:08 AM
Commercial Member
If you only knew how many conversations we've had about this. Long story, we had exposed hinges that held the doors open, but we had everything else as hidden hinges. Someone said they got complaints that the exposed did not look good, so we found some "hold open" hidden hinges. Well, they hold open a vertical door, not a horizontal door. The issue with struts, is if you install one, they can torque/shift the door over time. If you put two on to stop that, they slam hard...plus most are plastic and people think plastic is cheap. So, we found a new spring loaded hidden hinge, but the mounting point is too deep, we have to add a cleat.
So, its not being cheap, just trying to accommodate everyone's complaints and sometimes, if its not broken, we just need to explain why we do what we do before we decide to change. and just create a new complaint.
10-13-2017, 08:15 AM
Brian can we get a mfg or part # on the new hinges please?
Cindy & Walt
2018 DX3 36FK
2015 JKHR - toad
10-13-2017, 08:40 AM
I put struts on both sides of mine (made DW happy) also put struts on both cabinets over top of TV. easy, cheap, worked out well, been on since February.
Joe & Debbie
2017 Dynamax DX3 37BH
Toad: 2020 Ford F-150
10-13-2017, 08:51 AM
Commercial Member
DGN Soft Close Hinge 2952
10-13-2017, 08:56 AM
Thanks everyone....likes like there are some options all with pros and cons. I might try the spring option FFred mentions.
10-13-2017, 11:48 AM
The "spring option" has the advantage that one must use their hand to push the spring from straight to close .
Since ones hand is there the cover closes as you remove the hand , quiet , safe and no learning process for guests.
