Old 10-12-2018, 11:56 AM   #1
Caulking Needs Work
Hey guys...there are a number of you who are really in the know about these sorts of things. While washing my Isata 5 yesterday I noticed the caulking between the nose cone and the truck cab has splits in it. This coach is about a year old so some maintenance is expected. What kind of caulking should be used to fix this? Should the old caulking be removed or is it ok to go over the top of the old stuff?
ID:	188986   Click image for larger version
Tom and Becki
2018 Isata 5 30FW 4X4
bratbros is offline   Reply With Quote
Old 10-12-2018, 12:26 PM   #2
2012 Solera
Brian Clemens recently posted a chart of Dynamax external sealants:
http://www.forestriverforums.com/for...-168254-2.html
On our Solera, I use two types- Dicor Self Leveling and Dicor no-sag. For what you pictured, I would clean with acetone, then with denatured alcohol, then fill over the old caulk with no-sag.
Brian’s list may recommend a different caulk than what I use.
JLeising
2012 Solera "S"
Calif SF Bay Area
caulk
