12-11-2018, 09:23 AM
Ceiling AC/Heat vents
Before I break one, has anyone taken them down to clean?
Joe & Debbie
2017 Dynamax DX3 37BH
Toad: 2020 Ford F-150
12-11-2018, 10:25 AM
Yes they come off easily. Remove the plugs and just unscrew the four corners.
Scott & Heather
2018 Isata 5 DS
12-11-2018, 10:37 AM
I should have explained more
these..
Joe & Debbie
12-11-2018, 12:28 PM
I read on another forum that the exterior part pops off, maybe use a plastic trim tool to pry it off, screws are under it.
I have not taken mine off yet, that is on the list for this winter projects, I have two of them that need to be fixed (air vent has pulled away from the vent.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
The outside ring pops off to reveal the screws holding it to the ceiling. You can use a small flat blade screwdriver to pop it off. Several of ours are hard to adjust as they were mounted too tightly to the ceiling.
Phil and Jan
2018 Isata 5 36DS 4x4
2021 Jeep JL Rubicon
12-11-2018, 12:33 PM
I kinda tried to pop off the inner ring, but thought it was gonna break.
wife wants to clean them LOL. I guess the next question is to BC in case I
break one.
Where do you purchase these ? can you comment Brian?
Joe & Debbie
12-11-2018, 03:16 PM
Commercial Member
Those are priceless artifacts. Very expensive. I will give you my home address to send a check I will get them to you half off.
12-11-2018, 03:58 PM
No problem LOL
Joe & Debbie
12-11-2018, 04:38 PM
Commercial Member
I'm guessing you can get them on Amazon or from any dealer. There are a few different formats, ours have the pop-on ring to hide the fasteners.
My part number shows 55-ACG25CW (Coolvent) but I google that and some up with NOTHING. I don't know that I have ever gotten back zero results.
12-11-2018, 04:52 PM
That's cause your part # may be slightly off.
It likely is ACG25DPW-A
Here is one of MANY links on a Googler search...
Coolvent Deluxe Adjustable Ceiling Vent by Bell Mfg.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
12-11-2018, 05:13 PM
You guys are pretty good. Thank you much.
Maybe I won't break one or maybe she should clean them in the ceiling.
at least now I know where to buy them if they break.
Joe & Debbie
12-11-2018, 05:18 PM
Commercial Member
Originally Posted by 5picker
Well look at that...it would normally give me something close. Thanks for the assist.
Also, I think I goggled it with the 55...which is our plant number. We normally put 55 before the vendor part number.
12-11-2018, 05:45 PM
Rich Phillips
2019 K-2500 Duramax Crew Cab
2014 Silverback 33RL
12-11-2018, 06:12 PM
The vent has a friction ball pin in the center. Try to get a thin blade between the rotating ring and the flange so you can put pressure in the center to separate the two.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
12-12-2018, 01:17 AM
Old Navy Chief
2019 Isata 5 36' DS 4x4
2015 Jeep Rubicon Toad
Days camped 2021 = 25
12-12-2018, 05:04 PM
I am pretty sure the ones in our Force HD are the same vents, but they are not white, they are that tan color. I cannot find a tan one from the JR products, they only list white.
