Old 12-11-2018, 09:23 AM   #1
Ceiling AC/Heat vents
Before I break one, has anyone taken them down to clean?
Joe & Kathy
2017 Dynamax DX3 37BH
Toad: 2019 Ford F 150
2018: days camped 126
2019: days camped 70
joet19711 is offline   Reply With Quote
Old 12-11-2018, 10:25 AM   #2
sseaner's Avatar
Yes they come off easily. Remove the plugs and just unscrew the four corners.
Scott & Heather
2018 Isata 5 DS
sseaner is offline   Reply With Quote
Old 12-11-2018, 10:37 AM   #3
I should have explained more
these..
Joe & Kathy
Old 12-11-2018, 12:28 PM   #4
halla's Avatar
I read on another forum that the exterior part pops off, maybe use a plastic trim tool to pry it off, screws are under it.
I have not taken mine off yet, that is on the list for this winter projects, I have two of them that need to be fixed (air vent has pulled away from the vent.
2018 Dynamax Force HD BH---Just Rite-2
halla is offline   Reply With Quote
Old 12-11-2018, 12:28 PM   #5
The outside ring pops off to reveal the screws holding it to the ceiling. You can use a small flat blade screwdriver to pop it off. Several of ours are hard to adjust as they were mounted too tightly to the ceiling.
Phil and Jan
2018 Isata 5 36DS 4x4
2017 Jeep Cherokee Tralhawk
I5PhilGa is offline   Reply With Quote
Old 12-11-2018, 12:33 PM   #6
I kinda tried to pop off the inner ring, but thought it was gonna break.
wife wants to clean them LOL. I guess the next question is to BC in case I
break one.
Where do you purchase these ? can you comment Brian?
Joe & Kathy
Old 12-11-2018, 03:16 PM   #7
GM
bclemens's Avatar
Those are priceless artifacts. Very expensive. I will give you my home address to send a check I will get them to you half off.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 12-11-2018, 03:58 PM   #8
No problem LOL
Joe & Kathy
Old 12-11-2018, 04:38 PM   #9
GM
bclemens's Avatar
I'm guessing you can get them on Amazon or from any dealer. There are a few different formats, ours have the pop-on ring to hide the fasteners.
My part number shows 55-ACG25CW (Coolvent) but I google that and some up with NOTHING. I don't know that I have ever gotten back zero results.
Old 12-11-2018, 04:52 PM   #10
That's cause your part # may be slightly off.
It likely is ACG25DPW-A
Here is one of MANY links on a Googler search...
Coolvent Deluxe Adjustable Ceiling Vent by Bell Mfg.
Days Camped: '16=46 '17=30 '18=51 '19=27
vent
