Old 02-17-2018, 10:21 AM   #21
GM
bclemens's Avatar
Originally Posted by Jammer151 View Post
Are they in certain locations? When i picked mine up from dealer we had random spots above where the slides come in but fortunately they all came off.
That's actually pretty common. What happens in most cases is dust collects on the top of the slide out. It rains which creates dirty water. When the slide comes in...the slide seals reverse pivot to the inside and when they do that they can fling dirty water on the ceiling. I can't tell you how many times a customer has complained that they have a damaged ceiling and are mad...we take a wet wipe, wipe the ceiling and off they come.
Pink stuff is a whole other mystery
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 03-18-2018, 05:27 PM   #22
halla's Avatar
I stopped by the RV tonight to measure the feet on the Equalizer Jacks, snappads has the new feet available.
I went inside with the flashlight and noticed the stains, I have some on the wall too, I am guessing the bleach mixture shouldn’t be used on the wallpaper? Also there was spots on the ceiling, but only over the cab, not on the soft ceiling.
Any thoughts on removal of these stains, a bunch of the walls had them. It almost looked like they varnished the cabinets after they were installed and it splashed on the walls?
ID:	165564Click image for larger version
2018 Dynamax Force HD BH---Just Rite-2
halla is offline   Reply With Quote
Old 03-18-2018, 07:42 PM   #23
Attachment 165564Attachment 165565
Wow Halla I hate that for you. Man that thing is brand hammer new. Seems to be a common thing lately with this stain issue. I hate to say it but between the wiring problems sneaking out of the factory and these stains, PDI's and quality control is in question here. I know that I will get flamed for that comment and thats ok but for what these cost that is inexcusable in my unimportant opinion.
You should not have to clean that up. If you are close enough I would drive it back to the factory and tell them to clean that mess up. I know its the industry and all that yada yada yada but man you waited a long time on that coach and was about as excited as I will be to walk in and see that.
I know its nice having Brian on here helping answer questions on how to fix things but not things the factory should have fixed before it left.
Mountieman is offline   Reply With Quote
Old 03-18-2018, 08:25 PM   #24
sseaner's Avatar
Ceiling stains use the 50/50 bleach water with a microfiber towel. Takes a little elbow grease. Brian will have to chime in on the wall paper. I was able to remove all of my stains.
Scott & Heather
2018 Isata 5 DS
sseaner is offline   Reply With Quote
Old 03-19-2018, 07:34 AM   #25
caswelld's Avatar
I'm sure Brian already thought of this, but have the stains occurred anywhere other than the I-5s and DX3s? I haven't heard of any stain issues with the Isata 3s & 4s.
Are different processes used on the I-3 & 4 ceiling?
Dave & Julie
2018 Isata-3 24FW - Invisibrake/Roadmaster Falcon All-Terrain Tow Bar/2019 Wrangler Sport S 2.0 Turbo
2015 Tiffin Allegro 36LA/2014 Wrangler Sahara Unlimited
caswelld is offline   Reply With Quote
Old 03-19-2018, 10:12 AM   #26
GM
bclemens's Avatar
It seems pretty random and while I appreciate your concern Mountieman, you're assuming that we can see them.
Halla did not notice them when he took a very thorough deliver. It wasn't until he went back with a flash light. We have doused everything that we can in every chemical that we can and we can't recreate the staining. I'm not sure if its a combo of just the right temp, with just the right light or what.
The wall board is vinyl. I would test a small hidden spot first.
Old 03-19-2018, 11:33 AM   #27
halla's Avatar
I agree Brian, I didnt see them with the normal lights on and when I did the walk through, not blaming anyone, just want to try and get it fixed if I can. I will try a few things on the wall in a secret spot.
I do have a bottle of Oxy type stain remover, read on another RV Blog that it works to remove spots on ceilings and walls. I will report if I have any luck.
It seems that a bright LED flashlight shows you things your naked eye in normal light cannot see. Stupid flashlight.
Old 03-19-2018, 11:43 AM   #28
dlfishing's Avatar
Does look like varnish, seem like a warranty claim to me.
dlfishing is offline   Reply With Quote
Old 03-19-2018, 12:51 PM   #29
sseaner's Avatar
It’s definitely not varnish. The pink ones I know what they are. The yellow ones are a mystery.
Scott & Heather
2018 Isata 5 DS
Old 03-19-2018, 01:18 PM   #30
Well since you called me out by name I am " assuming " I stepped in muddy water. I directed my comment to Halla because I feel bad for the guy. I can tell he loves this stuff and spends a lot of time and money and seems like a good guy.
I am not assuming anything but merely stating facts. If I am wrong please correct me. There seems to be a mysterious stain showing up on the ceilings and walls after customers get home. Since its the same type of stain, we can assume its not the customer. I think we can agree the stain is there and happens pre-delivery and Dynamax keeps sending them out the door hoping it does not happen to this one.
We also have the electrical problem which there is absolutely no way possible those coaches were thoroughly inspected and each part of the unit tried out before it left the factory. This one could have been very dangerous. If the wires were crossed when they get home and things do not work correctly, I would guess the wires were crossed when they left the factory and did not work correctly. This to me seems like it would have been caught before it left which again brings up the quality control issue which would be a department at the factory I would guess.
Nobody is perfect and this is just a simple conversation between owners and future owners. You seem to work very hard and I was just stating an observation.
I do have concern for quality control as I would expect we all do. In my world perfection is the only satisfactory acceptance and should be what we all expect and strive for.
Halla I apologize and really hope you get the stains cleaned up.
P.S. Throw said flashlight away..
