Old 03-19-2018, 02:32 PM   #31
RV Randy's Avatar
We have the same type of stains in various spots on our ceiling. This was noted and documented when we were back at the factory doing a pre-delivery inspection. It was deferred to being an issue the dealer (Lazy Days) could deal with.
We did a pre PDI trip to Lazy Days and pointed this and other items out to their delivery prep team. I also gave them hard copies of the forum string on this topic recommending the 50/50 bleach solution. They claim they tried everything and could not get them off.
So I'm still waiting to see what the resolution is and/or what cleaning solution actually works safely.
Randy & Dee
2018 DX3 37TS
"Orange Crush"
RV Randy is offline   Reply With Quote
Old 03-19-2018, 03:56 PM   #32
If it helps at all I think this is a bigger issue than just Dynamax. I just traded in a 2015 Coachmen Apex and it had 2 stains that looked just like the pictures Halla posted. I always assumed the one on the ceiling was some type of adhesive. I never tried to remove the stain for fear of making the ceiling look worse. I haven't noticed them in our new camper (not a FR brand) but I will look very closely tonight...
____________________
2017 Silverado 3500 Z71 CC / L5P Duramax/Allison
2018 Grand Design Reflection 311 BHS
2015 Coachmen Apex 259BHSS 50th Anniversary (sold)
rjc1024 is offline   Reply With Quote
Old 03-19-2018, 04:18 PM   #33
I guess that confirms the " assumption " theory of we can see them before they leave the factory... I will be the bad guy here and dont mind at all.
Hind sight is 20/20 for everyone but the factory should have not let that out the door and pushing it on the dealer to try and clean up. Besides the stain issue Randy deserves a problem solver of the year for the electrical issue he worked out. I would be willing to bet 1 person out of 20 could have tracked that down. Not only an award but you deserved a check from Dynamax also for all the trouble you had to go through.
If you would have taken it back to the factory or to the dealer to figure out the problem, how much would it have cost Dynamax to fix these issues in time and labor??? I'll answer that... It would have taken a long time and a lot of money. You still deserve a check...
Mountieman is offline   Reply With Quote
Old 03-19-2018, 04:29 PM   #34
hook47's Avatar
Our 2013 Mobile Suites 5er had some; could only be seen if looking at them in the right light. Every time I go to our DX3 I mean to look at the ceiling. Keep forgetting or maybe conflict avoidance? Did have some of those wiper seal stains that rub off, like Brian mentioned earlier.
Perhaps these stains show up after a period of time? Not at initial construction PDI. Not trying to give any excuses, but it may take a cure period to show up.
hook47 is offline   Reply With Quote
Old 03-20-2018, 12:23 PM   #35
Randy are you waiting to hear from the Dealer, the factory or just anybody that figures out how to clean it off?
Old 03-20-2018, 03:30 PM   #36
judy3972's Avatar
Send a message via MSN to judy3972
Originally Posted by Mountieman View Post
Well since you called me out by name I am " assuming " I stepped in muddy water. I directed my comment to Halla because I feel bad for the guy. I can tell he loves this stuff and spends a lot of time and money and seems like a good guy.
I am not assuming anything but merely stating facts. If I am wrong please correct me. There seems to be a mysterious stain showing up on the ceilings and walls after customers get home. Since its the same type of stain, we can assume its not the customer. I think we can agree the stain is there and happens pre-delivery and Dynamax keeps sending them out the door hoping it does not happen to this one.
We also have the electrical problem which there is absolutely no way possible those coaches were thoroughly inspected and each part of the unit tried out before it left the factory. This one could have been very dangerous. If the wires were crossed when they get home and things do not work correctly, I would guess the wires were crossed when they left the factory and did not work correctly. This to me seems like it would have been caught before it left which again brings up the quality control issue which would be a department at the factory I would guess.
Nobody is perfect and this is just a simple conversation between owners and future owners. You seem to work very hard and I was just stating an observation.
I do have concern for quality control as I would expect we all do. In my world perfection is the only satisfactory acceptance and should be what we all expect and strive for.
Halla I apologize and really hope you get the stains cleaned up.
P.S. Throw said flashlight away..
The stains on our coach ceiling are visible with the naked eye and are not pink but a yellowest color. The stains appeared after a particularly heavy rain storm, they are all over the ceiling and not just in one area. As we are in Arizona this rarely happens so I made the assumption (I know better than to assume) that it was a roof leak. When I took the unit in for warranty work I was told it was not a leak but the glue that was used and it is leaking through and discoloring the ceiling. Still no resolution with this issue. Also so we have an issue with the ceiling lights on the drivers side in the living area. The lights keep failing. This post is for information purposes.
Life's a journey, enjoy the trip.
Phoenix, Az.
judy3972 is offline   Reply With Quote
Old 03-20-2018, 04:23 PM   #37
This makes good sense and I would think this could be correct. I guess if it is the problem when some are seeing it earlier then others maybe humidity, amount of glue used and maybe some other factors come in to play. Either way I think the ceilings should be replaced, coated, or something and made right for you guys. Maybe a resolution or solution will come around soon..
Old 03-20-2018, 05:34 PM   #38
GM
bclemens's Avatar
Originally Posted by caswelld View Post
I'm sure Brian already thought of this, but have the stains occurred anywhere other than the I-5s and DX3s? I haven't heard of any stain issues with the Isata 3s & 4s.
Are different processes used on the I-3 & 4 ceiling?
Nope. I have not seen it on the 3 or 4. Same roofing material is used. But as I said before...we have caught some and we fix them. Some just frankly don't show up until its down the road...and we can't fix what we can't see.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 03-20-2018, 06:46 PM   #39
judy3972's Avatar
How is this fixed?
Phoenix, Az.
Old 03-20-2018, 09:10 PM   #40
