Charging or not Charging that is the Question
OK, I have a question for the brains out there. I have a Series 4 Isata. It has been plugged in and stored in a warm garage for a couple of weeks. I went to put a slide in and the low power light started blinking. I stopped and restarted and got the same result. After a little while of thinking about it I decided to check the coach batteries and they seem fine. I then disconnected the power for a few minutes. When I plugged it back in the battery voltage went from the steady 13 volts to like 14.3 volts. I operated the slide, watching the battery gauge, and the voltage never went below 14 volts. There was no warning light on the slide either.
Guess my question is does the on board charger only charge a lower voltage once it has reached float? I restarted by unplugging and re-plugging even though the batteries were still well charged.
Feeling kind of dumb.
Bill & Sue
Southwest Missouri, retired
2018 Dynamax Series 4
2014 Explorer & 2006 Jeep Unlimited
