Old 12-14-2017, 06:53 PM   #1
hhl
Clear 45 degree sewer hose adapter Isata 3 24FW
Did not like having to bend way down and reach under rv to connect dump hose. Put my knee on dump station concrete, it is sometimes wet.
This one has a flush connector that I do not use but it was last one in rv store.
Now I can see the connector which makes connecting a lot easier.
ID:	158366Click image for larger version
hhl is offline   Reply With Quote
Old 12-14-2017, 08:03 PM   #2
Sandiegodoug's Avatar
I did that too, I also added a valterra waste valve too. Read that sometimes those valves on a wire might not close all the way, and when you take off cover get a nasty supprise
Sandiegodoug is offline   Reply With Quote
Old 12-14-2017, 08:14 PM   #3
hhl
Yeah, black tank valve works great. Grey tank valve has slow leak. Have to get it checked, warranty fix.
Grey tank discharge handle sticks out a little more than black tank discharge valve.
Luckely it is the grey tank.
Old 12-14-2017, 08:21 PM   #4
Another user had black tank leak
And got a nasty surprise, and added the valve. I just copied to avoid future surprises
Old 12-15-2017, 09:16 PM   #5
Greg-Gabe's Avatar
Not sure why they left the connection so far back... ordered a 9” clear extension on Amazon, with two titanium knees it’s hard to get down there to hook up the sewer hose....
Greg-Gabe is offline   Reply With Quote
Old 12-16-2017, 09:27 AM   #6
milkman55's Avatar
Great ideas. I always get to get down their to hook up and replace the cover. My unit is too new to have leaks yet, but I am sure I will get there.
2017 Isata 3 24FW
2014 Honda CR-V
milkman55 is online now   Reply With Quote
Old 12-21-2017, 11:15 AM   #7
Greg-Gabe's Avatar
The 9” extension comes right to the edge. Probably could have ordered the 7” but the 9” works well enough.
Old 12-21-2017, 01:31 PM   #8
milkman55's Avatar
I just ordered the 7” extension for $13 on Amazon. I agree with you, 7” should bring it out just enough to reach easily without being visible.
2017 Isata 3 24FW
2014 Honda CR-V
Old 12-21-2017, 03:57 PM   #9
xgarys's Avatar
Is the outboard end fastened to the coach or is the screw head on top for something else?
xgarys is offline   Reply With Quote
Old 12-21-2017, 05:37 PM   #10
Greg-Gabe's Avatar
I did not fastened it to the coach as the weight is minimal, the screw head is for the exhaust bracket for the generator. They are close but there is enough clearance between them so there shouldn’t be an issue...
