2017 isata 3 went out side this AM and all of the clearance lights are on, and I can't find a way to turn off. Have only had it a few weeks and it may be a simple issue but I don't know the answer. Any help would be appreciated.
That switch is just for the courtesy lights above each door. The clearance lights should be controlled by the Mercedes chassis lights. Shoot me your VIN and I can take a look. There was a recall out on the Curt controller...that exhibited issues just like that.
__________________ If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
So it just started exhibiting this behavior? And you're sure the head light switch is not on fog lights or anything like that? Headlight switch in the off position?
I plugged your VIN into the recall system and it is not part of the Curt Controller recall. I have an email into the electrical engineer to see if there is any known issue.
I have tried all of the easy fixes including disconnect of battery for 30 mins to no avail. I am going to take to dealer and see if they will look at it or if they just defer me to the Dynamax dealer.
Had this problem on a fifth wheel a few yrs ago. Turned out the factory had shot a staple through the wiring. It.eventually wore through insulation and shorted the clearance lights in the on position.
