Old 12-09-2019, 01:00 PM   #1
dbaction's Avatar
Compartment door weatherstrip
Here is an issue with my 2017 Isata 5 compartment door weather stripping. Recently noticed rust along the bottom rail of the weather strip on the wet bay and the fresh water bay. These compartments are occasionally wet from the outside sprayer or when changing water filters which caused rust to develop on both the compartment door edge and the weather strip. The compression metal tab that holds the strip to the compartment edge is completely rusted away.
Can someone (maybe BClemens) let me know if there is a replacement for the strip that uses either stainless or aluminum compression tab...???
Other Isata owners may want to check their compartments as it is hard to see the rust damage without moving the strip.
Thanks in advance for any help!
Don
dbaction is offline   Reply With Quote
Old 12-09-2019, 01:45 PM   #2
dbaction's Avatar
Don
Here's a pic of the strip and door edge...Click image for larger version
Old 12-10-2019, 11:49 AM   #3
GM
bclemens's Avatar
I know we have updated our door seals, but not sure the attachment has changed, just the profile.
I know many on here swear by POR-15??? Maybe some day the midwest will stop salting the roads.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 12-10-2019, 12:22 PM   #4
dbaction's Avatar
Thanks Brian.
Here's what I did to fix without replacing the door seal.
1. Pulled the seal(s) partially away to get at the rusted metal grip tabs of the seal.
2. Removed what was left of the rusted metal grip tabs with a screwdriver blade up to where the metal was still unrusted.
3. Sand papered the compartment door edges and cleaned.
4. Applied "Ospho" a rust inhibitor to the cleaned and prepped metal edges.
5. Applied thick bead of 3M weather-strip sealant (black) to the length of the seal where the metal grip tabs had rusted away.
6. Reattached the seals to the compartment edges.
The repair took about 45 minutes to complete.
Like the soup Nazi said on Seinfeld....."NEXT" !!
Old 12-10-2019, 12:32 PM   #5
GM
bclemens's Avatar
even better.
Old 12-10-2019, 03:27 PM   #6
KRedburn's Avatar
um. They use salt out here also (Washington state)
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
KRedburn is offline   Reply With Quote
Old 12-12-2019, 02:16 PM   #7
AWF1945's Avatar
Correct. POR 15 will do the trick. Just follow directions completely. More than likely you'll need to replace that seal. Once seal is replaced, put a small bead of Masterweld 620 around the lip of the seal and water "will not" enter the seal as shown in your picture. Least that's my experience.
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
door
