07-23-2017, 12:45 PM
confusing wet spot in bedroom on a Force 37BHHD
We discovered a small wet spot of carpet in the bedroom. Near the back wall, but the wall isn't wet, and there doesn't appear to be any moisture coming from the window. I lifted the bed and everything is dry near the fresh water tank. I looked underneath in the compartments and all appears dry. Has anybody else had an issue like this?
Larry
07-23-2017, 12:54 PM
Oh, that headline got my attention, I just read the first few words :rollback:
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
07-23-2017, 12:55 PM
Did you fill using the gravity fill?
On mine the hose clamp was tightened by a man with a few missing fingers so a good grip in the flathead screw driver was impossible
the caused water to track along the wall during the fill
07-23-2017, 01:12 PM
Condensation from overhead AC unit? On real humid days ours will drip inside a little.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
07-23-2017, 01:28 PM
That's the OTHER forum!
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
07-23-2017, 05:06 PM
A/c unit is too far. Was the leak near the bottom of the slide?
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
07-23-2017, 05:53 PM
The wet spot is about 2 feet away from the slide close to the wall, but the base of wall isn't wet
07-23-2017, 07:43 PM
I wonder if it came down the inside of the fiberglass rear cap until it hit the floor?
07-23-2017, 09:03 PM
I'm leaning towards that's all it could be. I flew my drone overtop of the roof, but didn't see anything suspicious, time to get up there on a ladder
07-24-2017, 06:59 AM
When I replaced the rear window you cam see a bunch of places where water could get in if not caulked properly
07-24-2017, 07:11 AM
WOW ! can't believe no one asked......Do you by chance....own a pet ?
07-24-2017, 07:12 AM
Then your wall would be wet...I would pull the carpet to see if it is running along the floor before you rot that cheap crap out...
Coachmen M/H
Concord
2018 / 300 DSC
07-24-2017, 07:13 AM
Get your head out of the gutter.....I did, after first read
07-24-2017, 01:25 PM
I was afraid to ask that but, you need to take the dog out more often.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
07-24-2017, 04:26 PM
I don't have a Dynamax, but I did have a strange small wet spot in the bedroom carpet at the back of my coach (it was definitely water)... Figured one of the kids spilled something and didn't think too much of it.
The next trip out, the carpet got totally saturated on the first day out (of a 3-week trip). Also found water dripping fast out back of coach to the ground.
A little searching, and was able to conclude that water was leaking out of plumbing that was routed under the rear closet floor, and over the engine compartment. Discovered that when the coach was built (2014), a screw that was driven into the closet floor pierced the PEX plumbing running to my water heater. It took 3+ years for the screw to rust enough that the puncture started to leak. The leak was very small at first, but quickly became a big problem.
I hope this helps! Your leak may be nothing, or it could be the sign of something bigger to come. It's definitely work investigating...
Carl
07-24-2017, 08:15 PM
No pet on board. I talked to the dealer today, he suggested getting on the roof and check the caulking at the back cap
