03-14-2019, 04:30 PM
Curling Valances
Has anyone out there experienced the ends of the pattered material valance plaque's curling up on the ends? And if you have what was your fix? Seems like they must be plastic covered in foam and material. They are fastened to the valance with velcro. Maybe they are heat curled? Ideas?
Old Navy Chief
2019 Isata 5 36' DS 4x4
2015 Jeep Rubicon Toad
Days camped 2021 = 25
03-14-2019, 04:49 PM
Photos of curled up valances.
Old Navy Chief
03-14-2019, 10:33 PM
Nope, not in my I5.
Pat
2017 Isata 5
03-15-2019, 07:18 AM
yes - I had this happen on my I3. A few became unattached. I ended up removing them all together.
2019 Isata 3 FW
03-15-2019, 07:27 PM
Fixed them all. They are made of cardboard and the velcro adhesive must have released in our Az/Cal heat. I used 1/4" staples to refasten the velcro to the back of the stick on valance plaques and curling solved.
Old Navy Chief
03-16-2019, 02:46 AM
I have not seen this before. It is a shame that something like this happened and you had to fix it. Glad you were able to take care of it in a way satisfactory to you. However, I must say I am surprised to learn carboard is used in the valance.
03-16-2019, 08:01 AM
The I5 has less hard wood than the bigger coaches too, more vinyl wrapped composites and such. Light weight. On the I5 they have to do a lot to reduce weight to improve CCC. Every little bit helps.
Old Navy Chief
03-17-2019, 09:14 PM
Location: Bellingham, Wa: Boise, Id;Rancho Cucamonga, Ca
same problem on our 30fw. adding more velcro, will see if it works. i think humidity is a culprit.
03-17-2019, 09:32 PM
Maybe, we don't usually get that but it has rained for the past two months so could be. Anyway the glue backing pulled off the paper so the 1/4" staples did the trick, I use the small ones on a little desk stapler. And the velcro seems to be holding them now.
Old Navy Chief
03-18-2019, 10:19 AM
Simple fixes are good!
Pat
2017 Isata 5
03-18-2019, 10:46 AM
Commercial Member
To be clear, I don't think it is cardboard. I know they sometimes use MDF panels. or Lauan. They also typically use OSB for the top material. We have now asked them to use lumber-core in the top of the valence so that screws hold better. We did that across the board about 6 months ago.
I know that MouseHouse wanted to recover her valances in the Disney, so we sent "just" the substrate material. As I recall when it came in, all the small pieces were lauan
03-18-2019, 02:32 PM
Valance may be wood, we are only talking about the patterned portion and that is velcro'd onto the covered (solid color) valance which is made of wood I think, it has screws into for the brackets. But look at the photo of the curled up material. The backing appears to be some sort of paper board with the fabric and some underlying foam stapled to it. The staples I used to refasten the velcro appear to be holding so far. I should have taken some photos of the back side.
Old Navy Chief
