Old 03-14-2019, 04:30 PM   #1
caseymyers's Avatar
Curling Valances
Has anyone out there experienced the ends of the pattered material valance plaque's curling up on the ends? And if you have what was your fix? Seems like they must be plastic covered in foam and material. They are fastened to the valance with velcro. Maybe they are heat curled? Ideas?
Old Navy Chief
2019 Isata 5 DS 4x4
2015 Jeep Rubicon Toad
Days camped in I5 2019 = 15
caseymyers is offline   Reply With Quote
Old 03-14-2019, 04:49 PM   #2
caseymyers's Avatar
Photos of curled up valances.
ID:	198755   Click image for larger version
Old Navy Chief
2019 Isata 5 DS 4x4
Old 03-14-2019, 10:33 PM   #3
Nope, not in my I5.
Pat
2017 Isata 5
Whalenss is offline   Reply With Quote
Old 03-15-2019, 07:18 AM   #4
yes - I had this happen on my I3. A few became unattached. I ended up removing them all together.
2019 Isata 3 FW
papazeus is offline   Reply With Quote
Old 03-15-2019, 07:27 PM   #5
caseymyers's Avatar
Fixed them all. They are made of cardboard and the velcro adhesive must have released in our Az/Cal heat. I used 1/4" staples to refasten the velcro to the back of the stick on valance plaques and curling solved.
Old Navy Chief
2019 Isata 5 DS 4x4
Old 03-16-2019, 02:46 AM   #6
I have not seen this before. It is a shame that something like this happened and you had to fix it. Glad you were able to take care of it in a way satisfactory to you. However, I must say I am surprised to learn carboard is used in the valance.
uh60silverback is offline   Reply With Quote
Old 03-16-2019, 08:01 AM   #7
caseymyers's Avatar
The I5 has less hard wood than the bigger coaches too, more vinyl wrapped composites and such. Light weight. On the I5 they have to do a lot to reduce weight to improve CCC. Every little bit helps.
Old Navy Chief
2019 Isata 5 DS 4x4
Old 03-17-2019, 09:14 PM   #8
Location: Bellingham, Wa: Boise, Id;Rancho Cucamonga, Ca
same problem on our 30fw. adding more velcro, will see if it works. i think humidity is a culprit.
Dick Skeers is offline   Reply With Quote
Old 03-17-2019, 09:32 PM   #9
caseymyers's Avatar
Maybe, we don't usually get that but it has rained for the past two months so could be. Anyway the glue backing pulled off the paper so the 1/4" staples did the trick, I use the small ones on a little desk stapler. And the velcro seems to be holding them now.
Old Navy Chief
2019 Isata 5 DS 4x4
Old 03-18-2019, 10:19 AM   #10
Simple fixes are good!
Pat
2017 Isata 5
