05-07-2019, 01:03 PM
DEF Fluid-Dynamax
I was wondering on where everyone buys their DEF. I know the truck stops have it, but it is too expensive. Two years ago I bought it in a 55 gallon drum, way easier to pump it in etc... but I couldnt use the whole drum before it went bad.
So I looked at Walmart, it is $12-14 for a 2.5 gallon box.
I just found it at Tractor Supply for $19.00 for a 5 gallon container. Has anyone used the TSC DEF? or anyother suggestions?
Thank you
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
05-07-2019, 01:16 PM
I only pay about $7 at Walmart for 2.5 gallons.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
05-07-2019, 01:31 PM
BluDEF is $12.47. They also sell a 12 pack of BluDEF gallons for $139.
I use the BluDEF just because I like name brands, it’s all personal opinion.
2021 Isata 5 30FW
2014 Honda CR-V
05-07-2019, 01:47 PM
I always carry a box or two of BluDEF and cycle them through the coach or my Ram before it expires, but it's just for emergencies. I almost always refill using the bulk DEF at the truck stops.
2018 DX3 37BH
05-07-2019, 02:06 PM
"Blue" from Wally world.
05-07-2019, 02:11 PM
Walmart at $7.50 for 2 and 1/2 gallons. I wondered how they could the same thing for $12.00 plus?
05-07-2019, 02:28 PM
BlueDef at Walmart is around $12 for a 2.5 gallon container. Their "generic" brand, called Tech - something, is about $7.50 for a 2.5 gallon container.
Tractor Supply will have BlueDef on sale once in a while for around $11. They are usually at $15 or $16 for a 2.5 gallon.
I don't find it too terribly expensive in bulk at truck stops, but with Silverado's fill spout up under the hood, passenger side, most of the hoses at truck stops are too short to allow me to fill easily while I'm getting diesel.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2021 Chevy Silverado 3500HD DRW 4X4 Duramax
“It's not how old you are, it's how you are old.” ― Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
05-07-2019, 02:29 PM
SuperTech DEF from WallyWorld for me.....$7.88 for 2.5 gallons and the Mfg date is clearly stamped on the container it's always fresh in my local store. I never had any issues.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30X
05-07-2019, 02:35 PM
define way too expensive? DEF at the truck stops is always between 3 and 4 dollars a gallon. Everything I see here is more that that with the bonus of not creating plastic garbage every 100 gal of diesel
2016 Dynamax DX3 - Big Blue
05-07-2019, 02:55 PM
DEF at the pump of my local Flying J is $2.95/gal, that's $7.38 for 2.5 gallons and no plastic waste.
SuperTech DEF @ Walmart is $7.88 for a 2.5 gallon jug and you have plastic waste/recycling.
So not sure how DEF at the pump is the "expensive" option?
As far as brands go, brand doesn't matter as long as the DEF is API certified. The freshest, cheapest, API-certified DEF is the way to go. That's going to be had from DEF pumps at truck stops. Next best is going to be SuperTech DEF from Walmart.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
05-07-2019, 03:50 PM
I get it as needed at the truck stop at the pump.
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
05-07-2019, 05:05 PM
Not to mention I'd have to haul that 55 gal drum around with me. I refil def 2-3 times per trip it seems
05-07-2019, 06:57 PM
Lol, I happen to like plastic garbage.
05-07-2019, 08:02 PM
Get at high volume truck stops like flying j, etc. Avoid the lower volume places just to keep issues at a minimum.
In a pinch I'll get blue def in a box.
Much simpler at the pump and never carrying a partial box.
Aaron
2019 DX3 36FK
All Electric w/Cab Over
05-07-2019, 08:03 PM
Commercial Member
Wait until they pull a DEF tank out of a turtles nose....then you'll only be able to get them in paper jugs.
05-07-2019, 08:19 PM
If people just Recycle the DEF jug or a water bottle no problem. At the Goshen Rally I have to collect my recycling and go to a local church as the Fairgrounds does not recycle. So backwards way to look after things IMHO. One Earth.
05-07-2019, 08:20 PM
I don't worry about such things, but I disagree that a truck stop HAS to have the freshest DEF. If you use 2 gallons a year or 2 million gallons a year, someone can over purchase or not FIFO it, and suddenly it's old. Gas stations just have much larger jugs (assuming IBC tote, but am just guessing).
If course, if a gas station gets a bad batch or old jug or whatever.... Their butt will be in the line in "liability" eventually. It's certainly not in their best interest.....
I feel bad DEF is an internet bigger-than-reality thing. Just MHO....
05-07-2019, 08:27 PM
Always get my def at truck stops since 2014. Never had any issues. Knock on wood.
05-07-2019, 08:43 PM
Not to go off on a tangent, but even recyclers are being overloaded with plastics. China has severely reduced how much used plastic they will take from us and they were the primary consumers of recyclable plastic. Now that demand for recyclable plastic is in the tank the recycling companies are being overrun with plastics that they can’t do anything with and they are having to resort to sending it to landfills or burning it if they can’t store it or find takers domestically. It’s still cheaper to make new plastic than to recycle it and with how many plastic products people purchase it’s becoming almost impossible to overcome. Microplastics are becoming a huge problem in the environment as well.
Not trying to come across as a tree hugger or anything, but plastic recycling is a joke currently. We really need to reduce our consumption of products that come in single-use plastic containers since recycling isn’t working.
If possible, fill up with DEF at the pump instead of buying it in plastic jugs.
2013 Shamrock 21SS
05-07-2019, 08:49 PM
The problem with Flying J is the price of diesel, 30 or more cents per gallon above others in same area.
