05-26-2018, 06:07 AM
Digital Movie Library on the Road
I’m looking for suggestions to bring my digital library of movies with me on the road. I currently run Plex at home and have ripped all of our DVDs and BluRays to my NAS. Most movies are MKV or mp4. I want to be able to play movies without the internet.
I can do a server/client setup like at home and get really fancy and sync the NAS content or I can go simpler. I could just copy all my video files to an external drive and plug it in to the tv.
Does anyone know the current model of TVs that are shipping with the DX3 TS? I’m wondering if the support my various movie files or if I’m going to need clients at each tv?
05-27-2018, 11:18 AM
I use a NUC computer and keep my backup movie and TV series files on a hard drive stack in the camper. I use a router capable of network extension as my camper's network backbone and connect it to the home network wirelessly.
When I add a new MP4 to my home network, I back it up to the camper at the same time. That way I have an "off site" backup of my MP4 collection.
I used to use Universal Media Server as my media file server, but switched to PLEX recently. If PLEX is internet dependent, I was not aware of it and will need to further experiment with it on the road. Going back to Universal Media server is possible if PLEX does not work out.
PLEX works great at home and my LG Smart TV loads and runs the movies wirelessly without any trouble at all. It "sees" the PLEX and UMS on the "input selection" screen off the main menu. I replaced the OEM TV in the camper with a larger LG Smart TV and it is connected to the NUC via HDMI.
For a one time fee of $5 per device, I installed PLEX Viewer on our iPhones and iPads and they stream perfectly over the camper's backbone. I have a projector and outside big screen and can stream movies to my laptop for group movies.
I will be at the FROG Brass Ring, Mayberry, Goshen, and the Balloon Rallies this year and can demonstrate how it all works if you have any questions.
Herk
PS - Hardware:
https://www.newegg.com/Product/Produ...82E16856102178
https://www.newegg.com/Product/Produ...82E16816111455
https://www.newegg.com/Product/Produ...82E16833281004
https://www.newegg.com/Product/Produ...82E16827136260
PPS - Very familiar with Kaysville as I lived in Layton for 5 years while stationed at Hill AFB and still have very good friends living in Roy.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
05-28-2018, 12:17 AM
Thanks for the awesome reply!! That's a slick setup. I'll have to check out the NUC with a JBOD. Not a bad idea. This also had my attention as an all in one since it claims to have decent horsepower for encoding. https://www.plex.tv/wd-my-cloud-pro-series/ I am concerned about noise so maybe that's why you went the NUC route? I currently run a synology NAS at home so I have to figure out the best way to keep the arrays in sync.
Things have started to change a bit on the west side of the base near Roy. Hill AFB carved out some land and is leasing it for a technology park they call Falcon Hill. It keeps growing...
Thanks again for your reply!
05-28-2018, 12:52 AM
I'm a big fan of the 'KISS' principle for RVs. If the TV in the Dynamax can play back mp4 and mkv (less likely though) by all means just get a sizable flashdrive or external SSD storage and be done with it.
If the TV has limitations like mine, personally I use a Raspberry Pi Zero W running Kodi velcroed to the back, connected via HDMI and powered from the TV's USB port. It does require an adapter from micro USB to connect the flashdrive so that's a bit of a pain, and if the TV doesn't support HDMI CEC you need to use your phone as remote.
If AC power availability is not an issue just get a media player or cheap Blueray with media file support. Check the file format support though.
05-28-2018, 06:12 AM
Heh I was going to say synology but sounds like you’ve already got on that wagon.
Barring that what about a small form factor pc you can leave wired in the RV that can cloud sync with the home synology?
2016 Dynamax DX3 - Big Blue
05-28-2018, 06:22 AM
The problem is that most (in not all), smart TVs have a limit (based on the firmware) on the maximum size file, flash drive size, and hard drive size it can directly access.
While you can "sneaker net" your movie to the TV via a properly sized flash drive (both my TVs have a 32G limit on a USB stick and 2T on a USB hard drive); it is a pain in the tush. I can not seem to predict what we want to watch until we coordinate with who ever is over to watch a movie. Trying to inventory a drawer full of sticks with 8-10 movies on it can be too much of a hassle. I have a small 2T drive stuck to the back of the camper TV as a backup in case the computer has a problem, but dragging it into the house to reload it with current movies is a pain.
Transferring terrabytes of data is time consuming.
05-28-2018, 06:25 AM
The NUC is perfect for that as it is 4 inches square and 2.5 inches thick.
HDMI output and 4 USB 3.1 inputs. The new i7 ones are VERY fast video servers. My i5 is plenty fast, though.
05-28-2018, 06:31 AM
The only time I don't power up the JBOD is when I am running the system on the inverter. I have 32G memory system drive and a 500G SSD IN the NUC.
If my next stop is without AC power, I will transfer a bunch of new stuff to the SSD ahead of time. The NUC draw is very low and so is the LED TV.
05-28-2018, 06:55 AM
Hmm I may have to look into that. Would fit perfect up in the AV cubbie. Granted my RV never makes it home so I'd have to manually transfer but that'd be better than buying blu rays as we are now lol.
05-28-2018, 07:59 AM
The actual dimensions of the NUC are 2.01"H x 4.37"W x 4.53"D
I use DVDfab to create the MP4. There are other programs, but this one is the best IMO. There is also an upgrade to the basic program that will convert your Blu-Ray at full Blu-Ray resolution. The basic program won't do Blu-Ray.
https://www.dvdfab.cn/
You can try all the features free for 30 days.
If your smart TV is 3D, there is a 3rd party plug in that will create a 3D MP4 backup.
05-28-2018, 08:36 AM
I use glue back Velcro tape to secure the electronic components to the shelf.
(Except for the NAS! I found the vibrations in my rear living room camper to much for the NAS cabinet and can unplug the drives. I use a 1 inch piece of firm foam above and below to secure the NAS and a strap across the front when traveling.
If you need to remove the Velcro tape a hair dryer will soften it up so it comes off easily.
05-28-2018, 09:38 AM
This is what I’m thinking for simplicity’s sake. It will auto sync with my home synology and when I pull into the driveway (with a wireless repeater). Main thing now I’m looking at power draw right now as a consideration. I want to be able to have this run all the time. Looking at either the DS218+ or DS418 play (which is supposed to be more power efficient).
On the 37TS is there an inverter powered plug by the front tv?
05-28-2018, 09:41 AM
Pairing the NUC with an m.2 form factor thunderbolt 3 array would be sick.
04-13-2021, 08:07 PM
Señor Miembro
What do you guys recommend these days for off line TV storage?
Particularly, amazon prime videos (APV)? I've got a bunch of APV downloaded to ipad and android phone but no good way to down load them for the TV's in the RV. Maybe a roku or Firestick plugged into the multiplexor so I can just cast from ipad or phone to that and distribute to which ever TV's I want? Though I'm sure I'd shortly endup with one cast device in each TV so the kids and grown ups can watch separate shows.
Right now we are still really old school doing blue rays or hard wire connecting the ipad to the TV with a usb-c to hdmi adapter.
04-13-2021, 08:27 PM
Old school works just fine for us.
I have 3 small footprint (1/2 x 3 x 5 inch) USB 5 Terabyte hard drives that I keep everything on (and I have a LOT) and a laptop we take camping.
1 drive is all TV shows, 1 drive is all movies, and the 3rd is a Data only drive that I keep all my RV repair movies and manuals on; as well as my important files, photos, and backups from home.
I just dump the movies or TV shows we want to watch to a 32 Gigabyte or smaller thumb drive and plug it into a Smart TV (if you have switched out your camper's OEM TV) or run a HDMI cable from the laptop to the OEM TV.
I am the guy you want to camp next to on a rainy day.
04-13-2021, 09:06 PM
2011 Rockwood Mini Lite 1809S
2013 Rockwood Ultra Lite 2304S
2004 Dodge Dakota SLT+ 4.7
2012 Ford F150 FX4 3.5 EcoBoost
04-13-2021, 09:10 PM
Originally Posted by jay2703
"Supports up to a 2TB external hard drive formatted in FAT,FAT32, and NTFS, the partition of the HDD should be MBR, not GPT."
My drives are near full, so looking for bigger ones. A 2T limit won't cut it for me, but for smaller collections it should work just great.
Spotted this one that will take a 4T drive. Now we are talking!
https://www.amazon.com/Atom-4K-Ultra...tronics&sr=1-4
04-15-2021, 04:33 PM
Consumer of Space
I have an extra Synology SAS I've been meaning to set up for this... It's on my list. When I get around to doing it I'll post some pictures here...
Sean
2018 Dynamax Force HD 37BH
04-15-2021, 04:42 PM
I have a NVIDIA Shield TV I connect via USB a 4TB drive (on the road I have a 8TB at home) with all my movies, tv, Music. I use Kodi as the GUI interface for the media while the shield doubles as a Live Streaming device you can also stream Netflix, Hulu, Disney + and hundreds more.
Beauty of this, you dont need WiFi/Internet to run or watch your movies, TV or music
** Newer NVIDIA Shield Devices do not have the USB for external but other models do.
https://www.amazon.com/NVIDIA-Shield...tronics&sr=1-1
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 47:2024 7
I use a Raspberry Pi as my server with a 2 TB USB hard drive attached to it. I currently have over 700 movies stored on it and I run Kodi. You could also run a Plex Server on a Raspberry Pi. In my old trailer, I had a 12 VDC TV, so I added a 5 amp USB power supply that ran off 12 VDC so I could use both the TV and Raspberry Pi server on battery power. My current trailer has a 110 VAC TV so my Raspberry Pi power supply is plugged into the same outlet as the TV.
You can use the master Raspberry Pi with the USB drive attached to it to create an ad hoc WiFi network. Then all you need for your other TVs are smart TVs that will connect to the Raspberry Pi server. Or just a Raspberry Pi client for regular TVs. I can also connect my phone, tablet and computer to my Raspberry Pi server and watch movies on those devices.
