yes, it all sounds typical of low battery voltage...
whether your battery bank is actually being charged is the question... they may be getting some charge while traveling(engine alternator), but it doesnt' sound like any charging may be happening while plugged into Shore Power. Your converter/charger certainly seems culprit... if you actually have a converter. Some coaches now have an INVERTER with an integrated Charger, and don't use a converter.
So, checking the output of the Converter is to start. The charger output would be next... and if you don't have a converter, making sure the CHARGER is actually turned ON would be key.
The Turners...
