Originally Posted by wanderer44
What is the clamp used for. Between my 3 inch valve and the tank? Is there a slip fitting to gain room for easier changing of the valve? thanks leonard
What is the "stuff" around the clamp? Perhaps some kind of sealer or epoxy?
If there is a crack or leak at this point perhaps someone applied some kind of sealer and reinforced it with a clamp.
