Old 03-19-2019, 06:33 PM   #1
Dump valve clamp?
What is the clamp used for. Between my 3 inch valve and the tank? Is there a slip fitting to gain room for easier changing of the valve? thanks leonard
wanderer44 is online now   Reply With Quote
Old 03-19-2019, 09:26 PM   #2
What is the "stuff" around the clamp? Perhaps some kind of sealer or epoxy?
If there is a crack or leak at this point perhaps someone applied some kind of sealer and reinforced it with a clamp.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 03-20-2019, 11:47 AM   #3
Head Rambler
That looks like where the nozzle on the tank slips over the piping and is secured with the clamp.
Can you back off just a little and take another picture?
Gotta go campin!
Old 03-20-2019, 11:50 AM   #4
Take off clamp and see. Dont know why its there and or whats with the sealant around it.
cmysstailights is offline   Reply With Quote
Old 03-20-2019, 01:57 PM   #5
More pics of valve clamps
The backed of pics of drain valve clamps!
ID:	199215   Click image for larger version
ID:	199216   Click image for larger version
ID:	199217   Click image for larger version
ID:	199218   Click image for larger version
Old 03-20-2019, 02:38 PM   #6
Head Rambler
Those are the tank nozzles. The pipe gets coated with sealant and slid into them. The clamp is put on there to help hold the piping in place and seal the connection. Since the sealant isn't glue (solvent cement) the pipe could slide out or leak over time.
Gotta go campin!
Old 03-20-2019, 06:26 PM   #7
I noticed the same thing on my 2018 trailer. It must be a new assembly method that can be repaired.
My 2010 trailer had valve fittings that were glued on and were not reparable.
I could not figure out how the tanks could be removed on my 2018 so guessing they have to be repairable in place.
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
Prior Rig: 2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is online now   Reply With Quote
Old 03-20-2019, 08:00 PM   #8
bubbles's Avatar
Looks to me like the clamps are just holding some sort of protective shroud in place (glued) that perhaps provides protection for the tanks or just cosmetic in nature. Nothing to do with plumbing. Just a guess.
valve
