Old 06-11-2016, 10:02 PM   #11
ablarson's Avatar
1/2 way there. Not sure why they felt the need to design these like a 70's Buick. Much firmer now.
Name:	ImageUploadedByForest River Forums1465700319.061856.jpg
Name:	ImageUploadedByForest River Forums1465700444.544288.jpg
Name:	ImageUploadedByForest River Forums1465700462.446615.jpg
Looks like it was sewed on a Friday.
Newbie
2 RV Trips to date
19 States
2016 Dynamax Force HD
ablarson is offline   Reply With Quote
Old 06-11-2016, 10:27 PM   #12
dea49's Avatar
Originally Posted by viperdave View Post
bc - sorry to be a pain...but your involvement in the forum will only make your product better and the owners happier.
I can totally understand how the table height could rise with the issue between the wire chase and a softer cushion and I will not just redrill into the wall to make sure I stay away from the wires. I'll look at your other suggestion to see if I can just make a stop at a lower height.
Thanks for the replies!
Dave
I am currently installing the Dream Dinette Mechanism. My wife didn't like how high it was and wanted it 2-3 inches lower so a quick but permanent fix was I pushed down the table to the point where the height was to her satisfaction, marked that point on the bottom of the table and mounted the guide up to that point. I drilled a hole in the guide, back the length of the nylon slide and put a bolt through it to stop the nylon slide from traveling any further in the guide.
Now the table rises until the nylon slide hits the bolt and stops. A flip of the manual bar lock and the nylon slide is now sandwiched between the bolt and the manual bar lock.
Problem solved.
@bclemens: If the guide came with a preset hole the proper distance behind the lock grove and a bolt. It would make this mechanism much more versatile just by moving the guide forward to lower the maximum height of the table.
dea49 is offline   Reply With Quote
Old 06-12-2016, 04:03 PM   #13
My table was high also. All I did was unlocked it lowered it to the height I liked. Leaving it at that height I went went under the table and marked the position of the slide unit in the track. I then drilled a 3/16 hole into which I inserted a bolt. Works great as the table can not go down lower. Then I turn the lock unit back on. That is behind the slide trapping the slide between it and the screw. The table can't lower or raise up in it's own. I have had no issues of it raising on it's own. Hopefully I can add a couple pictures of what I did.
RetiredAF1955-1981 is offline   Reply With Quote
Old 06-12-2016, 04:15 PM   #14
table mod pictures
Here are a couple pictures I hope go thru.
Name:	Table Slide 1.jpg
ID:	110917   Click image for larger version
Name:	Table Slide 2.jpg
ID:	110918   Click image for larger version
Name:	Table Slide3.jpg
Old 06-13-2016, 06:38 AM   #15
Wolverine 1945's Avatar
Sorry I did not realize what type of table you guys were talking about !!!
Wolverine 1945 is offline   Reply With Quote
Old 06-13-2016, 09:58 AM   #16
viperdave's Avatar
What thickness of plywood did you use? Thanks for the photos, I'll do this next.
I did a few measurements and I believe that bc is correct on how all of this happened. My table is about 31" and I sink down in the cushion to about 15". I found a little indent in the poly bracket that I used to click the factory catch rod into and this gives me a table height about 28". If I firm us the seat with plywood this might be ok. If not I planned to make a new notch in the rail and shorten the catch rod so that I have a table that moves the way it was designed without having to undo a bolt.
viperdave is offline   Reply With Quote
Old 06-14-2016, 10:30 PM   #17
ablarson's Avatar
3/4" Birch
Your welcome, it was super easy.
Newbie
2 RV Trips to date
19 States
Old 06-15-2016, 07:00 AM   #18
viperdave's Avatar
Thanks again for the info, it is on my list of upgrades
Old 06-15-2016, 12:35 PM   #19
I did not either, I was discussing the type in the 06 Dynaquest, the old style with the posts, same problem as the others just different fix,.
Bill340 is offline   Reply With Quote
Old 06-16-2016, 05:49 AM   #20
Right On Bill !!!
Just get out the Hack Saw !!!
LOL !!!
