Old 11-27-2017, 11:44 AM   #21
jkoenig24
Brian, can you say what the difference in fuel economy is from the original settings to the performance settings? What did the Allison shop charge to reprogram? TIA!
John
jkoenig24 is offline   Reply With Quote
Old 11-27-2017, 12:11 PM   #22
John,
As far as mileage I don’t think it is even noticeable. I get anywhere between 6-9 mpg. The fee was around a $100. They actually call Allison to approve the program change that took longer than the actual reprogram.
Brian
bkballard3 is offline   Reply With Quote
Old 11-27-2017, 03:53 PM   #23
murraym's Avatar
Originally Posted by 4DayJeep View Post
I have been reading lots of these threads - I plan on using our unit on order DX3 37TS to go cross country. Do these units have plenty of power to pull the grades?? Not looking at going 70 MPH over the grades on Hwy 80 or ones like the grapevine on I-5, but don't want to drop to 30 MPH either. Wondering since I saw you could upgrade to the M2-112 chassis and get another 100 horsepower and 250 more ft/lbs of torque.
2015 DX3 37BHHD M102 pulling a loaded up 26' trailer. Go back and forth between Philly and Indianapolis often. It pulls up the grades just fine, and comes down just as easy with the engine braking. There is only one grade that makes it work for it. I know where it is by terrain and know that when I get there, I just get a little bit of a running start up to about 75-80 for about a mile and it makes it up without getting below 55. If I hit it at 55mph because of heavy traffic or I'm not paying attention, then it will drop down to about 30-35 and I just move over to the right out of everyone's way just like the trucks. It makes it with ease though.
It is what it is. Deal with it, and get to fixing it. Anything is possible with enough time and or pressure.
murraym is offline   Reply With Quote
Old 11-27-2017, 06:42 PM   #24
Hi there,
Similar to you I only drop to about 35 mph on the steepest hills without the extra run to the hill. In these cases I am always towing a ram 1500 4x4. Hope this helps!
Brian
Old 11-28-2017, 09:24 AM   #25
FOURWHL's Avatar
Originally Posted by tnrzryd View Post
Hey FOURWHL - what rpm do you like to hold as a minimum when climbing? I’ve always watched the tach and manually downshifted to hold the rpms up to prevent overheating. The sweet spot on my last coach was 1500.
A lot of the time I just let the Allison do it's thing. Will lose a little momentum but always stay above 40. If I want to try and sustain 45 or 50 I'll usually think about downshifting in the 1300 to 1500 range. That usually bumps it up near 2k I think. Hard to drive from memory though
2016 Dynamax DX3 - Big Blue
FOURWHL is offline   Reply With Quote
Old 11-28-2017, 09:35 AM   #26
Yes as I recall it will shift on its own at about 1300 -1500 rpm. The sweet spot I believe is about the same.
Old 11-28-2017, 10:18 AM   #27
FOURWHL's Avatar
Sometimes I've watched it go down as low as 1000 which like I said is fine, but does result in a little bit of momentum loss that you likely won't get back until cresting
That said it's nothing in comparison to getting stuck behind somebody doing 20 and then trying to reaccelerate!
Old 11-29-2017, 12:01 AM   #28
All this sounds familiar. When driving and facing long uphill hauls, a good run at it never hurt. Sure hope we can afford to order our DX3 sometime in the very near future.
Tom and Regina
DX3 wannabes
2 fur kids
tnrzryd is offline   Reply With Quote
power
