Old 10-16-2016, 09:07 AM   #1
Dx3 Inverter Question
I recently purchased a 2015 36Fks and I am getting a E05 0L code on the inverter. Inverter is a Xantrex Pro 1800 and the fault code says overload or short circuit. So in trying to figure this out I need to know what the inverter supplys ac power to in the rig. Everything seems to be working with shore power or generator but no power to the fridge when disconnected from AC power.
Webefine is offline   Reply With Quote
Old 10-16-2016, 09:29 AM   #2
halla's Avatar
Sounds like a ground is bad/loose. Not sure what all is supplied by the inverter.
2016 Dynamax Force. Just-Rite2
2016 Dynamax Force---Just Rite 2
halla is online now   Reply With Quote
Old 10-16-2016, 09:52 AM   #3
Xantrex has wonderful tech support. 800-670-0707. If no one answers leave a message with model # and what your issue is and they will call back very promptly
rvsparky is offline   Reply With Quote
Old 10-16-2016, 09:07 PM   #4
Thanks for the replys. I did some investigating today and I believe that the inverter is bad. I checked all connections and grounds all where good then I disconnected the wire for AC power coming out and AC power coming in and still had the same error code. So at that point I basically had a inverter connected to batteries with no load wires at all and still had the same problem.
Old 10-18-2016, 08:42 PM   #5
I spoke with Xantrex tech support and they confirmed the inverter is bad and needs replaced. I am thinking of upgrading to the Freedom XI 200o, it is a pure sine wave inverter. From what I have been reading a modified sine wave isn't that good for running a refrigerator and may shorten its life span and some phone / computer chargers may run hot. Anyone have any firsthand knowledge of this?
inverter
