02-13-2017, 10:30 AM
DX3 wet compartments
All the outside compartments get wet when traveling in the rain. There are large holes where rails go through the side at the top. Open to outside spray. Open rear fenders wells throw spray all over generator and slide mechanism. Does anyone have a solution.
02-13-2017, 10:39 AM
What year is your DX3
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
02-13-2017, 10:42 AM
Wet compartments
2016 dx3 37ts
02-13-2017, 10:49 AM
Do you have the steel or plastic bays
02-13-2017, 11:24 AM
Fiberglass
02-13-2017, 12:50 PM
polypropylene.... not fiberglass. I agree the generator is subject to more of the elements than it should be.
02-13-2017, 04:04 PM
Commercial Member
Sounds like new compartment door seals are in order or a latch adjustment. We have run a few different type of door seal. A round bulb seal, or a sort of "U-shape" seal that creates a gutter for water over the top. If the door is adjusted properly, either works...but I think the round bulb seal might be the most forgiving.
02-13-2017, 08:42 PM
I spent some time caulking the compartments where they are attached to the outside steel. It stopped some of the spray during heavy rains while driving and a lot of dust.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
02-14-2017, 10:01 AM
The moisture is not coming from the doors. It is coming from spray from rear wheel well and open battery and generato compartments, traveling down rail that runs length of compartments and then down rails for slides that open into the top of compartments. You can physically put your hand through the hole into the battery compartment. If you look up in all the compartments you can see the exposure to the elements. Already had to change zantrex because it got wet when we left dealership after buying it. Drivers side worse than passenger. I don't know how it can be fixed.
02-14-2017, 11:31 AM
Commercial Member
Pictures?
02-14-2017, 12:22 PM
Pictures?
I'd like to seem them too...
02-14-2017, 01:17 PM
[ATTACH]129885[/[ATTACH][ATTACH][ATTACH] [/ATTACH][/ATTACH][/ATTACH]]
I hope these pics help explain the problem.
02-14-2017, 01:23 PM
I can't seem to be able to attach more than one pic .
02-15-2017, 08:41 AM
Commercial Member
Expanding foam would take care of that as long as it doesn't interfere with a slide ram moving in and out. In that case, a rubber flap cut snuggly to the opening.
