Old 09-19-2019, 07:43 AM   #1
Dynaquest XL - Icemaker
Commercial fridge ... icemaker no longer making ice. Have water to the fridge since the water dispenser is working just fine. Thoughts?
DieselBurn is offline   Reply With Quote
Old 09-19-2019, 08:44 AM   #2
Jim34RL's Avatar
Just a wild guess but is the ice maker switch turned to off?
My home fridge and my residential fridge in our trailer have switches to turn off the ice maker. In the RV fridge it is a lever that you raise to the up position. Let us know what you find out?
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 09-19-2019, 09:05 PM   #3
RV Randy's Avatar
X2. Also make sure your water pump is turned on if not on city water hookup. Also check how low the freezer temp is set to. Sometimes it can make the water line to the ice maker freeze up.
RV Randy is offline   Reply With Quote
Old 09-19-2019, 09:06 PM   #4
No switches ... the on/off control is on a digital panel in the door ...
Old 09-19-2019, 09:49 PM   #5
2018 Dynaquest 38TS
There is a on off setting on the digital panel on the door.
DR Quest is offline   Reply With Quote
Old 09-20-2019, 07:45 AM   #6
I have replaced my ice maker twice. It is not making ice again. Not a very good design .
Worm43 is offline   Reply With Quote
Old 09-20-2019, 08:43 AM   #7
halla's Avatar
Took my icemaker out, more room in the freezer and I dont like the idea of that being able to leak.
2018 Dynamax Force HD BH---Just Rite-2
halla is online now   Reply With Quote
Old 09-20-2019, 08:56 AM   #8
Delco Bobby's Avatar
So your ice maker does not have a wire in the ice bin that has to be in the lower position to make ice? If in upper position it will not make ice.
The wire can be easily moved especially if someone likes to grab ice from the ice bin.
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 09-20-2019, 01:16 PM   #9
When bought my 2018 DX3 (used), the ice maker wasn't working. Took it to the local RV repair shop and they said it was low on refrigerant. Works great now....
WanderingPhoto is offline   Reply With Quote
Old 09-20-2019, 01:30 PM   #10
x2 with WANDERINGPHOTO
When our refer was going bad we had the same problem. My RV guy replaced the cooling unit when ammonia oder started. He told me the freezer has to be cold enough for the ice maker to make ice. The same ice-maker puts out serious amounts of ice now that we have a new cooling unit.
hupmat is offline   Reply With Quote
Old 09-20-2019, 03:57 PM   #11
Residential?
Originally Posted by DieselBurn;2187216[COLOR="Red"
]Commercial fridge[/COLOR] ... icemaker no longer making ice. Have water to the fridge since the water dispenser is working just fine. Thoughts?
When you say "Commercial fridge", do you mean a Residential fridge as you would have in a sticks-and-bricks home? Not an absorption fridge?
If you do, here's a well-kept secret. Just about all icemakers from all manufacturers are the same. They come from the same third party. And here is how you can diagnose it. You will need a six-inch piece of 14 AWG solid wire, stripped for 3/4" inch at each end.
https://www.appliancerepair.net/refr...-repair-8.html
Larry
Larry-NC is offline   Reply With Quote
