Old 09-04-2016, 12:42 PM   #1
ablarson's Avatar
Entry door flapping while driving
Anyone else have this issue? The top and bottom of the door flap pretty bad. It's really noisy and looks a little dangerous. I didn't notice it until recently. Is there any type of adjustment that can be made? Could something have gotten tweaked driving down the road or possibly when leveling?
Newbie
19 States
2016 Dynamax Force HD
ablarson is offline   Reply With Quote
Old 09-04-2016, 06:42 PM   #2
Larson-can you get a couple of pictures of top and bottom when the door is closed? Your problem sounds like you might need to tighten / adjust your entry door locking mechanism.
Mike
2016 Force HD
Mike
2016 Force HD 36
BLK-9 is offline   Reply With Quote
Old 09-05-2016, 10:28 AM   #3
GM
bclemens's Avatar
Normally those doors are cambered to prevent that (or at least try to). Are any windows open? Normally its pressure inside the coach that would cause that.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 09-05-2016, 02:23 PM   #4
ablarson's Avatar
Name:	ImageUploadedByForest River Forums1473103104.464870.jpg
Name:	ImageUploadedByForest River Forums1473103119.959989.jpg
No windows open on the inside. I checked the door seals also. I do have both ACs running while I'm driving down the road if that matters. I tried to take a video but this forum won't allow you to upload videos. You can push in on the bottom of the door from the outside and it pushes in about a half an inch before it stops. At 65 it's annoying, at 78 it sounds like we're getting ready for takeoff.
Newbie
19 States
Old 09-06-2016, 07:14 AM   #5
GM
bclemens's Avatar
Definitely looks like that door needs some adjustment. Should not be sticking that far out.
door
