Old 03-20-2018, 07:10 PM   #1
halla's Avatar
Equalizer Leveling Bluetooth Module
I ordered the Equalizer bluetooth module yesterday. It came in today. By far the easiest thing I have ever hooked up on the Force. Unscrew the control panel, unplug the one harness, plug the harness into the new module, plug the module back into the control panel. Download the app (iphone in this case). You set up a security pin so no one else can control your jacks. Worked like a charm. Now I can run the jacks from anywhere around the coach. Wohoo.
My new Equalizer SnapPads should be here shortly.
2018 Dynamax Force HD BH---Just Rite-2
halla is offline   Reply With Quote
Old 03-20-2018, 07:12 PM   #2
Cool. Anxious to see some pictures of your coach once you have some of the different accessories installed.
steverkemp is offline   Reply With Quote
Old 03-20-2018, 07:16 PM   #3
halla's Avatar
May be a long wait. I am busier than normal at work. Need to take a week off and get my projects done. Lol
Old 03-20-2018, 09:13 PM   #4
tagalex
tagalex's Avatar
The box is small, easily installed behind the manual jack panel.
App requires you to the link the device to the app every time, but its as simple as dragging the finger over the bluetoothID then enter a personal pass code configured on initial setup.
i like it because i can level and watch my kids place the landing pads. (they have graduated to using the fire poker these days though)
i also have the snappads arriving next week, but in some of the crazy places we camp, will still use additional pads in some spots to keep it level.
Name:	2018-03-05 14.17.56_s.jpg
ID:	165782   Click image for larger version
Name:	2018-03-07 09.55.58_s.png
ID:	165783   Click image for larger version
Name:	2018-03-09 16.38.49_s.jpg
my dx3 mods
tagalex is offline   Reply With Quote
Old 03-21-2018, 07:08 PM   #5
halla's Avatar
Here is a link to where I purchased the module. They are a rally sponsor too.
https://www.rvupgradestore.com/Equal...ule-p/3427.htm
Snappads came today, going to put por15 on the feet before the pads to ward off moisture.
Old 03-21-2018, 08:24 PM   #6
tagalex
tagalex's Avatar
halla,
did you order the octagon style?
If so, any chance you can take some quick pics of the equalizer snappads? Just curious because when ordering i was not sure the images reflected the new model that supported the octagon shape of my landing gear.
Tony
my dx3 mods
Old 03-21-2018, 08:56 PM   #7
halla's Avatar
I ordered the 4 Octagon series. This is what they look like, they are not Octagon shaped on the inside rim.
Old 03-22-2018, 12:52 PM   #8
dlfishing's Avatar
Attachment 165854
I donít remember the results of the original conversation on this 🤪
What is the purpose of using Snap Pads? Doesnít look like the would spread the load much more than the original steel jack pads.
dlfishing is offline   Reply With Quote
Old 03-22-2018, 08:05 PM   #9
halla's Avatar
I added them instead of putting pads under the jacks for soft ground or gravel.
Old 03-24-2018, 10:37 AM   #10
Halla, that Bluetooth upgrade is a great idea and will help when manually leveling. I ordered it from our sponsor, RV Upgrade store. You have a knack for finding the coolest gadgets. Keep them coming!
JRM63 is offline   Reply With Quote
equalizer, leveling
