Mookie, I wanted to ask you if you did the actual filter changes yourself. I had different filters on my generator than the replacement filters that I ordered. I received the exact parts you listed in your post. The oil filter was larger in diameter. The gasket o ring was larger but it still covered the area okay as it is not leaking. The fuel filter was a little larger and I had a hard time getting the clamp tightened, that goes around the filter. It also did not have a direction arrow on it like the one I took off. So I installed it like I thought it should go. Just was curious what you experienced. As far as the 5W-40 goes, the temperature does get -10 to -20 sometimes and I think it gives me better protection? Thanks!
Space Cowboy
2018 Isata 5 30FW
