Old 10-02-2016, 03:00 PM   #11
2017 REV
Congrats on your new REV. We looked at a 2016 REV very nice rv. I will confirm the h2o pump is under the shower pan and accesible through a panel. Not sure why its not working though.
markb422 is offline   Reply With Quote
Old 10-02-2016, 03:31 PM   #12
Usually Confused Member
emm-dee's Avatar
The second time I took my TT out I didn't have any action from the water pump when I flipped the switch. Fusing checked okay so I accessed the pump (under the bathroom sink in my trailer). Was going to check for input voltage at the pump and when I moved some of the power wires the pump activated. Discovered the 12vdc wire was loosely connected and pushed it back onto the terminal spade. It's been working flawlessly ever since then.
Sometimes (well, probably all the time) the factory folks get a little hurried and don't take the time to do it right.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 10-02-2016, 03:43 PM   #13
Welcome to the Forest Ricer
Welcome to forest River your problem have only begun
jim bo is offline   Reply With Quote
Old 10-02-2016, 06:24 PM   #14
litgrep's Avatar
Does the water pump light on the monitor panel light up, is the winterizing valve in the flowthrough position, is there water in the tank, can you hear the pump? Are other 12v sytems working? Check all the 12 v fuse to be inserted fully. You on shore power or running only on battery? All questions to run down.
Roy and Gail with Rosie and Toby lucky dogs
2013 Salem Hemisphere 286 RLT
2009 Silverado 2500HD
litgrep is offline   Reply With Quote
Old 10-03-2016, 08:13 AM   #15
Commercial Member
zgipson's Avatar
I'm sorry to hear about your problem with the water pump. If the dealer cannot help figure out what is going on, our service department may be able to help troubleshoot the issue. Our number is 888-295-7859, ask for the service department.
PLEASE do not send questions via Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
zgipson is offline   Reply With Quote
Old 10-03-2016, 09:33 AM   #16
Originally Posted by Bob Vaughn View Post
You did not state whether you turned the water pump on at the master control panel and whether there was water in the holding tank.....
Do what he said.
If that doesn't work I believe the fuse box is directly below the control panel, just above the steps, on your right.
2017 Dynamax REV 24RB
Delco Bobby is offline   Reply With Quote
Old 10-03-2016, 10:29 AM   #17
mike.t's Avatar
Is the OP still with us?
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 10-03-2016, 12:44 PM   #18
Commercial Member
zgipson's Avatar
There is a rocker switch for the water pump on the main control pane next to the entry door. That switch must be on to draw water from your fresh tank when not hooked up to city water.
Old 10-03-2016, 04:00 PM   #19
GM
bclemens's Avatar
OP is posting over on our Facebook page. I sent him here as I was predisposed and thought the troops could help out,
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
bclemens is online now   Reply With Quote
Old 10-03-2016, 04:41 PM   #20
mike.t's Avatar
It appears the troops ARE trying to help out, If the OP gets the issue resolved have him let the forum know what is was then they can close it or?
2015 Salem 27RKSS
55' Chevy Bel-Air
pump, water, water pump
