Old 10-02-2016, 10:59 AM   #1
First day 2017 -no water pump ?
The new REV 24RB has no water pump activity or noise ?
The EXTERIOR shower compartments system check monitor LEDs is also out
Can not see in any manual where pump is located?
Perhaps a fuse check ?
Where is pump/ext control center fuse? Not listed on fuse panel cover diagram
Is the pump protected only with an In-line fuse ?
Sorry to bother you so soon, be neat to use the facilities if I can fix this
I consulted, the usb manual, folder of papers, app download, on line as well…..no info for pump location or fuse to check…,
Al
Alkuplz is offline   Reply With Quote
Old 10-02-2016, 11:06 AM   #2
Kanadian Kamper
kenandterry's Avatar
I'm not even sure what kind of a rig you have let alone what a REV is.
My shower compartment doesn't have LEDs so not sure what we're chasing here either.
Love to help but we need more detail.....and pictures work better.
Ken and Terry
kenandterry is offline   Reply With Quote
Old 10-02-2016, 11:10 AM   #3
SeaDog's Avatar
Welcome to the forum its a great place to get help. With that said you may have better luck getting an answer if you tell the forum what type of rig you have and the year model. Lastly if you figure out what is causing the problem please let the forum know what you found.
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-02-2016, 11:13 AM   #4
nomad297's Avatar
He stated he has a 2017 REV. It is a Dynamax. Here's a link: Rev Motorhomes by Dynamax RV
Bruce
Old 10-02-2016, 11:42 AM   #5
Kanadian Kamper
There ya go.
I thought he was reporting a problem with his first day out with a new 2017 something.
I was not aware of the models of that line of RVs.
And the LED issue....is that just LED lighting or LED status lights he is reporting as out?
Ken and Terry
Old 10-02-2016, 12:17 PM   #6
BooBoo23's Avatar
Sounds like you need to go back to your dealer and get more information. While you are there you may want to find out how to winterize since they probably didn't show you that either. Maybe B Clemens will show up on the forum, he works for Dynamax and is usually monitoring this forum.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 10-02-2016, 12:23 PM   #7
Water pump
You did not state whether you turned the water pump on at the master control panel and whether there was water in the holding tank.....
Bob Vaughn is offline   Reply With Quote
Old 10-02-2016, 12:28 PM   #8
H2O pump
I have a 2016 REV RB. My h2o pump is under the shower pan, accessed by removing the panel in the bathroom beneath the shower door.
rev24RB is offline   Reply With Quote
Old 10-02-2016, 01:13 PM   #9
Welcome to the forum.Did you do a PDI or walk through with the dealer? Should have been full of water to make sure all is working well along with other operations of TV/stereo/fridge/ect.
mike.t is offline   Reply With Quote
Old 10-02-2016, 01:13 PM   #10
bikendan's Avatar
Did you fill the FW tank?
Old 10-02-2016, 03:00 PM   #11
2017 REV
Congrats on your new REV. We looked at a 2016 REV very nice rv. I will confirm the h2o pump is under the shower pan and accesible through a panel. Not sure why its not working though.
markb422 is offline   Reply With Quote
Old 10-02-2016, 03:31 PM   #12
The second time I took my TT out I didn't have any action from the water pump when I flipped the switch. Fusing checked okay so I accessed the pump (under the bathroom sink in my trailer). Was going to check for input voltage at the pump and when I moved some of the power wires the pump activated. Discovered the 12vdc wire was loosely connected and pushed it back onto the terminal spade. It's been working flawlessly ever since then.
Sometimes (well, probably all the time) the factory folks get a little hurried and don't take the time to do it right.
BIRDS AREN’T REAL
Old 10-02-2016, 03:43 PM   #13
Welcome to the Forest Ricer
Welcome to forest River your problem have only begun
jim bo is offline   Reply With Quote
Old 10-02-2016, 06:24 PM   #14
litgrep's Avatar
Does the water pump light on the monitor panel light up, is the winterizing valve in the flowthrough position, is there water in the tank, can you hear the pump? Are other 12v sytems working? Check all the 12 v fuse to be inserted fully. You on shore power or running only on battery? All questions to run down.
2013 Salem Hemisphere 286 RLT
2009 Silverado 2500HD
litgrep is offline   Reply With Quote
Old 10-03-2016, 08:13 AM   #15
Commercial Member
zgipson's Avatar
I'm sorry to hear about your problem with the water pump. If the dealer cannot help figure out what is going on, our service department may be able to help troubleshoot the issue. Our number is 888-295-7859, ask for the service department.
PLEASE do not send questions via Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
zgipson is offline   Reply With Quote
Old 10-03-2016, 09:33 AM   #16
Delco Bobby's Avatar
Do what he said.
If that doesn't work I believe the fuse box is directly below the control panel, just above the steps, on your right.
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 10-03-2016, 10:29 AM   #17
Is the OP still with us?
Old 10-03-2016, 12:44 PM   #18
Commercial Member
zgipson's Avatar
There is a rocker switch for the water pump on the main control pane next to the entry door. That switch must be on to draw water from your fresh tank when not hooked up to city water.
Old 10-03-2016, 04:00 PM   #19
Commercial Member
OP is posting over on our Facebook page. I sent him here as I was predisposed and thought the troops could help out,
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 10-03-2016, 04:41 PM   #20
It appears the troops ARE trying to help out, If the OP gets the issue resolved have him let the forum know what is was then they can close it or?
pump, water, water pump
