Old 10-12-2016, 09:57 AM   #1
Floating Fridge
On my 16 DX3 the refrigerator is not bolted down rigid. There are metal stops that keep it from coming out of its space but it can move front to back and side to side.
I want to bolt it solid from the bottom front.
Any reason why this is a bad idea ??
rvsparky is offline   Reply With Quote
Old 10-12-2016, 10:41 AM   #2
GM
bclemens's Avatar
Just the typical CYA from the fridge supplier that if you put holes in their fridge it will void the warranty.
PLEASE do not send questions via Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 10-12-2016, 11:02 AM   #3
General approach not specific to Dynamax:
I would start by either going to look at another similar unit and/or calling Dynamax to discuss the normal installation of your refrigerator and your concerns and/or calling the refrigerator mfg to discuss it with them.
You may (should?) be able, from outside your unit, to access the rear of the refrigerator. You could then put a couple of screws from the bottom of the metal refrigerator frame into what may be a plywood floor.
I think that would be better than a couple of screws in the front unless you use two front and two back.
There are probably height adjustment rubber feet in the front of the refrigerator.
Would a hole in the bottom metal frame void the warranty, not sure, mfgs use all kinds of excuses to get out of their warranty obligations.
I have installed three refrigerators in non-Dynamax units. We did not screw them down as they fit securely in their slot. I have seen videos of DIY install where they installed refrigerators that were smaller than original and they used a couple of screws in the bottom back aluminum frame to secure it. I don't think they considered the warranty.
Philos3 is offline   Reply With Quote
Old 10-12-2016, 12:02 PM   #4
There is an existing hole in the frame where the front wheels are. Looks like I can fasten through them. Just wanted to make sure there wasn't a reason to having it "loose"
Thanks for all the input
Old 10-12-2016, 12:02 PM   #5
GM
bclemens's Avatar
These are residential fridges, so no access from behind.
Old 10-12-2016, 12:13 PM   #6
My residential fridge has an access panel on the rear, low down. If I remove that panel, a lot of the key refrigerator components are accessible, as well as the frame.
Access to the refrigerator from outside the unit should be available by removing the refrigerator air flow panel.
Old 10-12-2016, 02:18 PM   #7
halla's Avatar
The access panel on the front lower side covers the furnace. No access to fridge. Mine does not move around luckily. Looking forward to seeing what options are offered.
2016 Dynamax Force. Just-Rite2
2016 Dynamax Force---Just Rite 2
halla is offline   Reply With Quote
Old 10-12-2016, 02:34 PM   #8
I drilled through the metal stops on the bottom front of the fridge, then placed a wooden spacer then bolted to the bottom frame of the fridge. It's very solid now. Just don't want to rip up the bottom piece of wood that the front stop is screwed to. ��
I feel pretty good about it though.
My problem now is I'm out of projects to fix on the unit. ��
Old 10-12-2016, 03:46 PM   #9
Halla,
I took a look at some pictures of a new Force via the internet, and I was surprised not to see a couple of louvered vents for the refrigerator. I'm guessing that if they put in a residential refrigerator it may not be required.
Maybe the vents related to the multi fuel sources on the non-residential refrigerator...the propane to be specific.
I'm guessing the chance of a refrigerator fire is minimized with a residential refrigerator.
Old 10-12-2016, 04:49 PM   #10
GM
bclemens's Avatar
No need for vents because there is no burner. Only a gas absorption fridge requires that. Residential just needs proper air flow around the coils.
fridge
