Old 06-30-2017, 07:56 AM   #1
shultz01's Avatar
Fluid Leaking from Dually Hub
Went out yesterday and did a walk-around in prep for our next trip tomorrow and discovered fluid had leaked from the rear dually hub. It wasn't much. I snugged up the nuts on the hub cover. Is this an immediate concern that should postpone our trip or can it wait until we get back in a week?
Name:	Hub Leak1.jpg
Andy & Debbie Shultz
Harrisburg, PA
2018 Force HD 37TS
shultz01 is offline   Reply With Quote
Old 06-30-2017, 08:18 AM   #2
sseaner's Avatar
Looks like the flange gasket leaking. Were you able to tighten the bolts any? Clean the rim and hub really well and take it for a drive. If it is still leaking, the oil will be slung out onto the rim. Replacing the gasket is about a one hour job at any truck repair center and will costs you about $150.00. How long was it sitting? That could give you an idea of the severity of the leak. Just keep your eye on it.
sseaner is offline   Reply With Quote
Old 06-30-2017, 10:30 AM   #3
shultz01's Avatar
Dropped it off at Freightliner. They just called. The hub covers on both sides were only torqued to 1/3 the spec!!
Harrisburg, PA
2018 Force HD 37TS
Old 06-30-2017, 11:49 AM   #4
They tell you what the actual spec is?
mookieblaylock is offline   Reply With Quote
Old 06-30-2017, 12:36 PM   #5
DAISY BOYKIN's Avatar
WOW
What a good call. I bet you are relieved.
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 07-01-2017, 05:11 AM   #6
shultz01's Avatar
150 ft/lbs
Harrisburg, PA
2018 Force HD 37TS
Old 07-01-2017, 05:15 AM   #7
shultz01's Avatar
Yes, indeed! I'm lucky to have two good Freightliner locations about 20 minutes each from my house. One is huge and the other is smaller. I've taken my Seneca and now my Force to the smaller one. It's good when the staff knows you!
Now it's off to Maine!
Harrisburg, PA
2018 Force HD 37TS
Old 07-01-2017, 05:57 AM   #8
Did they say how much Lube they had to replace? Youroo!!
leak
