Old 08-10-2016, 03:20 PM   #1
Force Coach battery charge from alternator
vehicle - force 37bh
symptom - inverter call E1 ( low voltage) message after a relative short period of driving (1.5h). Fridge on inverter, front tv and dvd also on inverter at the same time.
question - How to verify the coach batteries are being charge by the alternator when driving down the road?
I have followed a few of the recent threads about the coach batteries and understand that they should be charge after the chassis battery get charged up. OF late I find this may not be occurring with the symptoms above. I have even added two more agm for more amp hours
The batteries charge fine with generator and shore power. Xantrex reads 13.6v when on shore power, but only 12.4- 12.6 when not on shore/ generator with engine running and fridge tv/dvd on
battery level reads 2/3 when fridge is on (load) then goes to full when fridge is off
how can I verify batteries are being charged by alternator as there should be more than enough amp hours supplied by the battery ?
myhorse is online now   Reply With Quote
Old 08-10-2016, 03:54 PM   #2
GM
bclemens's Avatar
You say "of late" meaning it was charging before or at least you had no low voltage warnings before?
How old is your Force?
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 08-10-2016, 04:04 PM   #3
It Is a 2015 purchased new this summer
Our first trip back in june we were able to run of the inverter for nearly 5 hours
last weekend we got about an hour and a half
going out again this weekend and going to measure again
Old 08-10-2016, 07:17 PM   #4
I check the charging voltage when on gen power, shore power or engine alt power by looking at attached picture. I am always above 13v on either of the three energy charging sources. Hope this helps.
Name:	ImageUploadedByForest River Forums1470874621.500791.jpg
Mike
2016 Force HD
Mike
2016 Force HD 36
BLK-9 is offline   Reply With Quote
Old 08-10-2016, 07:21 PM   #5
Thanks Mike
I think that is where the problem is.
I get over 13v on gen and shore, but 12.7 on alternator.
Is there a way to check whether the converter or isolator has failed?
Old 08-11-2016, 04:59 AM   #6
My recommendation is to first check output voltage at the alternator.
Mike
2016 Force HD
Mike
2016 Force HD 36
Old 08-11-2016, 06:18 AM   #7
You already checked it...its not charging from your alternator or it should be in the 13.75 to 14 volt range with the engine running. If your coach is like most, the BCC controls the feed of the alternator to the house batteries. If you have a boost switch for starting, that fires the same solenoid to connect up the batteries as the internal circuit does.
First check the voltage on the starting battery with the engine running. If it isn't above 13 volts, your alternator is the problem. I would then look at the house battery voltage with the engine running and the boost switch depressed. If the voltage doesn't change, then the isolation solenoid is the problem.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 08-11-2016, 01:14 PM   #8
My bad my horse. I read your reply to the alternator reading ~12.7V was displayed on the Xantrek, which is why I recommended a reading directly from alternator-to get that reading first.
Mike
2016 Force HD
Mike
2016 Force HD 36
Old 08-14-2016, 05:07 PM   #9
well negative on the charge from alternator
batteries charge beautifully from shore/gen but nothing from alternator
anyone know where to start?
Old 08-15-2016, 08:55 AM   #10
GM
bclemens's Avatar
Could be the BIRD module...possible block fuse on that line. If you PM me your cell I can see about having the electrical engineer give you a call. There are a few places to check he says.
battery
