Old 08-05-2016, 05:53 PM   #1
Force exterior TV
TV is poor reception when on park.cable, both interior tvs are fine. Is there a splitter that i can access?
AndrewC is offline   Reply With Quote
Old 08-05-2016, 07:24 PM   #2
halla's Avatar
Splitter is behind the tv and the sink. I accessed under kitchen sink. I put on all new ends and a new splitter. Had to run a new cable from there to the bedroom, had really bad reception.
I did put the outside tv on a pull out swivel mount, easier to view since it is mounted so high. Easier to get to the cabling too.
2016 Dynamax Force. Just-Rite2
2016 Dynamax Force---Just Rite 2
halla is offline   Reply With Quote
Old 08-05-2016, 08:10 PM   #3
Found it, all ends are/were loose. Still no go, when we return, new splitter and ends
Young now I need to see your exterior mount mod.
Old 08-05-2016, 08:16 PM   #4
halla's Avatar
Can get pics maybe tomorrow.
Old 08-06-2016, 07:00 AM   #5
Awesome.. horns are done, great improvement. Thanks again, these should be standard in the unit.
Old 08-06-2016, 11:31 AM   #6
halla's Avatar
Here are the Pics for the TV. As you can see I changed the TV to a LG Smart TV, changed the stereo and speakers. so I added a weather proof 32" tv cover from Amazon, just in case water was to get in the cabinet. The TV bracket is found here...Articulating Mounts for TVs Fit 32€ - 65€ Flat Panel Plasma Screens It folds up to a little over an inch thick, which worked out perfectly. Lastly i covered the holes behind the TV, This keeps the bugs out of the coach, you will see there are some large access panel behind the TV. I bought 1/8" plastic sheet on Amazon, cut and added stainless screws.
ID:	116449   Click image for larger version
ID:	116450   Click image for larger version
Old 08-06-2016, 11:45 AM   #7
This is next on the list, did you reinforce the plastic mounting surface to accommodate the new mount?
Old 08-06-2016, 11:46 AM   #8
And I like the furnace covers!! Brilliant
Old 08-06-2016, 11:56 AM   #9
halla's Avatar
My mounting box was metal, no reinforcing.
Old 08-07-2016, 07:51 AM   #10
While sitting inside during a small storm here in the mountains of PA, I took the time to troubleshoot the tvs. Splitter under sink is no go, so I will replace this week. I will also be doing the exterior TV mod later in the week.
exterior
