__________________ If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
The alternator first charges the chassis battery to full and then will provide charging to the coach batteries but at a slow rate. Fastest way to charge the coach batteries is with the engine running start the generator and charge the coach batteries that way
Retired Navy
2016 Flagstaff 26 FKWS
So, our gen will not start with engine running. Is gen start provided via coach batts?
You should have a momentary switch that connects the house batteries to the start circuit, you push that and start the generator if affect you are jump starting the generator. At least thats how my Class A worked
Retired Navy
