07-11-2015, 07:23 PM
Force Levelers
Anyone had any issues with their level jacks? We had the dealer reset them and they still lean to the passenger side enough that the fridge slams shut and the shower door wont stay open. I am going to try and reset the zero point myself with a carpenters level, maybe the dealer didn't do it right.
Also have to have my tvs rewired, they only work on antenna, not on park cable, which is a bummer.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
07-12-2015, 07:21 AM
If your antenna has a power booster turn it off, it may be interfering with the park cable signal.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
07-12-2015, 07:53 AM
Left Coast
Different input on tv?
07-12-2015, 07:59 AM
It could be a separate input on his but on mine it's the same coax. If my antenna booster is on my park cable won't work. I have separate inputs for sat and DVDs.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
07-12-2015, 08:03 AM
Left Coast
My toshiba needed a different input, but my samsung didn't.
07-12-2015, 01:40 PM
only one input and the booster was off. I think it was just wired wrong or something was left unhooked.
2016 Dynamax Force. Just-Rite2
07-12-2015, 01:57 PM
Left Coast
Pull the other wall plate and see if there's a coax and maybe the splitter is in that area.
07-12-2015, 02:01 PM
Will do, good idea
07-27-2015, 04:41 PM
Our levelers would throw a fit while on the road, alarms and lights galore. System was powered off as well. Seems the res was not filled with Hyd. Fluid, and a low level issue would trip while in motion.. Check your levels!!!
07-27-2015, 04:42 PM
I noticed our level is a little low. I believe they recommend using dot 3 brake fluid.
07-27-2015, 08:33 PM
It is type a transmission fluid per powergear manual.
