Old 07-21-2016, 09:40 PM   #1
Fresh water tank drain valve?
Can anyone tell me where I can find the valve to open the fresh water tank drain?
I can see the drain tube in the outside compartment that also has the propane switch. I can not see the valve to this drain.
Dynamax REV 24 RB.
Thanks,
Bobby
2017 Dynamax REV 24RB
Delco Bobby is offline   Reply With Quote
Old 07-21-2016, 10:09 PM   #2
Scubanut's Avatar
Just a suggestion, it may not have a valve. It may just have a plug like a low point drain point. Both of my previous trailers did not have a valve until I installed one. I realize motor homes have compartments for these things but might be worth checking.
2012 F150 FX4 Crew 5.0 3.73 gears
2O12 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
Old 07-21-2016, 10:11 PM   #3
Good point, I will take a closer look although I would probably have noticed a plug.
Thanks.
Old 07-22-2016, 09:04 AM   #4
GM
bclemens's Avatar
It is a valve, but not a turning valve...its a pull valve.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
bclemens is online now   Reply With Quote
Old 07-22-2016, 01:55 PM   #5
JustJ's Avatar
Ours is kind of nestled above the black valve and the 2nd gray tank valve. You have to stick your head in there and look up. Sometimes the handle is folded flat.
JustJ is offline   Reply With Quote
Old 07-22-2016, 06:45 PM   #6
OK, you put me on the right track.
It appears to me that my FW tank drain is in a different location than other models. It is closer to the front of the vehicle and the access is via the propane door.
I took another look and saw the pull valve on a blue hose. I thought the white hose was the drain hose. Maybe that is the overflow hose. Whatever , I now know where it is located and I appreciate the assistance.
The pull valve is located to the right of the white hose in the photo on the right.
drain, fresh water, tank, water, water tank
