10-25-2017, 03:35 AM
#21
Yes I see. That does sound good flipping sides like you show. I’m not up and up on these types of panels.
2020 Ram 1500 classic 5.7l hemi 3:21 rear 8 speed
2019 Palimino XLE 24 RD
10-25-2017, 07:47 AM
#22
Commercial Member
I posted this a while back. I know the TS is not done yet...but the RB and the BH are done.
10-25-2017, 01:52 PM
#23
Brian,
Thank you for that information on the inverted circuits.
Do you know if/when the 36FK's will be moved over to the "future" side of that table? I ask only because our 36FK is due to start production soon and would love to have the outlets on the inverter.
Thanks!!
10-25-2017, 02:08 PM
#24
Commercial Member
That one is not in the near future. The TS is the next one to go. FK and DS is TBD.
10-25-2017, 02:15 PM
#25
Brian, thanks for that quick reply!
I, too, will have to look at moving the breaker to the inverted side of the panel. If that can even be done. Here's hoping!
10-25-2017, 03:14 PM
#26
Brian,
Thanks for the info. Can you comment on my last panel configuration. Is it within code?
Is it a viable configuration? It for the most part just swapped sides for the shore/generator with the inverted
Seems my 37TS is part way to the future side. Kind of in between
Are you going to use the same power distribution panel that is in mine
(progressive dynamics pd5500)?
Thanks,
Ken
10-25-2017, 03:48 PM
#27
Commercial Member
ooh, those are very tricky questions. "Within code" is a very wide often misinterpreted statement. I would have to show this to my electrical engineer and then I will get a long response about how we can not possible determine if it is within code as we cannot see the connections that are made, if they are made properly or if the loads balance properly.
Best I can get is that "it does not appear that you will blow anything up, but no guarantees"
10-25-2017, 04:16 PM
#28
Thanks for the quick reply.
By within code I mean circuit count/load on each side.
I know you cannot guarantee that I will make connections correctly.
Most of the work will just be to move breaker to new location on panel.
Does the configuration work? Is it similar to what you have planned on the 37TS?
Maybe PM would be better.
Ken
10-25-2017, 04:25 PM
#29
Commercial Member
I'll pass this on and have engineering take a look. They can at least compare to the BH.
10-26-2017, 09:59 AM
#30
thank you sir!
that would be great
10-26-2017, 10:48 AM
#31
Commercial Member
PS. Engineering thinks the plugs are flipped in the back. Should flip the Fireplace and TV plug ins.
10-26-2017, 11:06 AM
#32
Rats. Now I have to get go go gadget arms to reach those!
10-26-2017, 11:17 AM
#33
Commercial Member
that's what kids are for.
10-26-2017, 11:28 AM
#34
I am 240 lbs. Kid is ex football. 260lbs working on farm
Maybe wife
10-26-2017, 11:23 PM
#35
OK. Fireplace was plugged in to the gfci receptacle. Tv into the unmarked receptacle.
Swapped tv now works on inverter.
(My very first post was a clue here)
This all started after being brought up to the dealer of the issue. Dealer also thought there was a wiring error and said that he would have to run a new line to the inverter. I took the coach home and started digging into the issue. I also assumed that the plug in was done correctly since this unit with the optional fireplace and pop up tv was factory installed.
Thank you Brian for forwarding to engineering for comment. Fresh eyes always helps.
I do have one more question though.
One of the 2 HDMI cables to the living room TV is bad. Referred in post #5
How difficult would it be to replace this?
Thanks again,
Ken
10-27-2017, 10:15 AM
#36
Commercial Member
Define "one of them is bad".
(1) is for DVD
(1) is coming off of a splitter of for the satellite.
Which one is not working? DVD or Sat.
Do you have Sat installed?
Did you change the input's?
Are you plugged in? The HDMI splitter is powered.
Does the bedroom TV get a signal?
10-27-2017, 10:35 AM
#37
originally sat was ot working. sespped cable from dvd to splitter. sat was now on tv. all pther tv's work.
swapped ports on tv. no change
swapped short extension no change
swapped extension coupler. no change
only get sat OR dvd on cable marked fire 2. at the livingroom tv
10-27-2017, 12:39 PM
#38
Commercial Member
That one most likely runs underneath the coach to get from the front to the TV area. I'll have to ask my guys to be sure.
10-30-2017, 02:01 PM
#39
Commercial Member
Ken...my AV supplier actually came back with a better solution than running new cable or an AB switch...although arguably the AB switch is less money, it adds unnecessary connections and a little more complexity.
Just replace the existing splitter with
https://www.amazon.com/Monoprice-Bla...ter+and+Switch
Then you can send the Sat or the Bluray to any TV
11-15-2017, 05:28 PM
#40
thank you Brian for the suggested solution. I did some additional research and came up with this criteria:
One of two hdmi cables to front tv bad. -- need to be able to switch sat or dvd to common cable without interrupting other tv.
bedroom and outside have dedicated dvd so only need to have sat send to cable for each
front tv 2 inputs to 1
back and outside 1 input to 2
need 2 X 4 matrix switch
output 1 front tv
output 2 rear tv
output 3 outside tv
input 1 sat
input 2 dvd
configure:
in 1 to out 1 out 2 out 3
in 2 to out 1 when needed
If a person wants to continue watching dvd on other tv just set output X to input 2
purchased from.
https://www.hdtvsupply.com/2x4-hdmi-matrix.html
works great!
Ken
