07-01-2019, 12:32 PM
Generator Exhaust
Has anyone use the GenTuri exhaust system to get the generator exhaust above the coach? When boondocking that is probably my biggest irritation right now...it's the smell not so much the noise. With the windows open and the fans on the fumes get drawn inside the coach.
https://www.amazon.com/Camco-Gen-Tur...-1-spons&psc=1
Tom and Becki
2018 Isata 5 30FW 4X4
07-01-2019, 01:04 PM
I'm pretty sure TitanMike has posted photos/video of using something like that to get his generator exhaust above the R/V.
I'll see if I can find his post(s)...
See post # 19
And post # 15232
07-01-2019, 02:43 PM
DW's 401(k) Plan
I have a GenTuri for "just in case". I put it on when I start up the gennie in the driveway and the DW is working in the motor home. Works as advertised. [emoji106]
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
07-01-2019, 06:40 PM
I have one as well, works great.
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
07-01-2019, 10:16 PM
I've used one and works well. Does help a little with exhaust noise. Not so much mechanical noise.
Not tried it with the new coach yet since you use a special exhaust adapter and haven't wanted to take the nice chrome exhaust tip off the generator yet.
Aaron
2019 DX3 36FK
All Electric w/Cab Over
07-02-2019, 09:43 AM
Do you use the suction cups to mount the stack? I don't want to put any holes in my coach or mess up the paint....
Tom and Becki
07-02-2019, 09:54 AM
I used the suction cups on the toy hauler. Even had an extra section to get above the roof. Had no problem. The adapter on exhaust pipe definitely doesn't look as nice as the factory chrome tip. Just getting the I5 ready to go. Might be an issue with the door on the electronics/battery bay going full open. Haven't used the genturi on the motor home yet.
John & Sylvia
W. MT/W. AZ
2019 Dynamax Isata 5 30FW 4x4
2016 JKUR
07-02-2019, 10:50 AM
Just get an extra adapter and install the chrome tip on it. Might have to purchase a short piece of the right sized exhaust pipe from a local muffler shop (or maybe they'll give you a free piece of scrap). Then you can change from GenTuri to Chrome tip, merely swapping by pulling/reinstalling pin.
To the OP, it sure does get the "fumes" up and away from the RV which not only alleviates the smell, it also makes sure that Carbon Monoxide is dissipated away from windows. The GenTuri not only directs the exhaust gases away, they are greatly diluted by the excess air drawn in at the bottom of the stack. This excess air also keeps the stack cool enough to touch even though the generator may have been running at full power for hours. Just beware because the metal elbow will be hotter than the dickens.
07-02-2019, 06:41 PM
Mine came with adhesive mounts that I stuck on the wall.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
07-02-2019, 06:50 PM
I got the system but rarely use it. I didn’t notice any difference in noise level. The only time we start the generator is for quick rest stops while traveling, and they are so short I’m not gonna take the time to hook up the system.
If I need extended generator use I’ll start up the Hondas which will run continuously for five days on the same amount of fuel the Onan uses in a day.
BIRDS AREN’T REAL
07-02-2019, 07:08 PM
We have diesel generators, a different animal all together. I dry camp for a month at a time and use the generator occasionally to keep the battery’s up when cloudy and solar not keeping up or to recharge after running the furnace a lot. The diesel hardly uses any fuel at all. I can’t imagine having to carry extra generators.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
07-02-2019, 07:16 PM
Don’t know about diesel units but the Onan I have uses ½ gallon per hour. That’s 12 gallons a day. The dual Honda units use six gallons over 40 hours.
BIRDS AREN’T REAL
07-02-2019, 07:59 PM
Honda definitely has the best and quietest generators on the market. I only wish more people would use them in campgrounds instead of the cheap noisy ones. The gas Onans Aren't to bad when built into a coach.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
07-02-2019, 09:46 PM
Cannot use my generator because it discharges under the full wall slide on my i3 and fills the rv with gas. Used a gen-Turi on my old Navion. I could attach it to the ladder. I have the Gen-Turi but have yet figured out how to install. Just another problem to solve. Cannot figure out how Dynamax engineering was thinking. The generator also has an unbearable droning noise so I agree with BD - why do I need to use it anyway - only on cloudy days.
2019 Dynamax Isata 3 FW
RVing for 40+ years
07-03-2019, 06:01 AM
I would reroute the exhaust away from the slide. Mine on the RW exited on the passenger side. I moved it to the drivers side and added a muffler. I also added sound deadener to the generator housing. I just wanted it away from the outdoor living space.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
07-04-2019, 04:57 PM
Bill, what kind of muffler and sound dampers did you use? I need to relocate the exhaust pipe and find a way to reduce the noise, you get a chance! Thanks
07-04-2019, 06:08 PM
Pictures
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
07-05-2019, 05:20 PM
I’ve used the Genturi for three seasons of Gator Football tailgating. We cannot run the genset without it. Is makes it quieter, eliminates the exhaust smell and does help with the heat too. A great help when your tailgating on asphalt all weekend.
Rob & Rosanne Rzasa
2017 Dynamax Isata 5 36DS
Towing 2005 Honda Big Ruckus
Go Gators
