05-04-2019, 04:29 PM
Getting cold feet....
So I'm at the point in my solar install where I need to start drilling holes in the roof...
I'm trying to double and triple check myself to make sure I get it right the first time.
I've got the roof print for my unit and think from the vents and skylight I can work out the location of the trusses, but trying to drop my power cables down the control pedestal behind the driver seat.
It looks like that pedestal may partially overlap the front cap? Anybody have any insight as to whether I can get access direct to the roof from that pedestal? Would the entry point where the antenna and satellite be better? Not sure how to access that from inside though. The pedestal drops down perfectly to the batteries for me
2016 Dynamax DX3 - Big Blue
05-04-2019, 04:30 PM
Pics attached this time
05-04-2019, 04:50 PM
Ugh the roof print I have is 37BH with cabover. Any chance that's why truss location isn't lining up?
05-04-2019, 05:29 PM
A very ambitious project. Don't know the answer but did a search and came up with this. http://www.forestriverforums.com/for...x3-161036.html Maybe you don't have to drill.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
05-04-2019, 06:06 PM
Man, I am not sure I could do it. I would be a nervous wreck. Probably doesnt make you feel better, lol. hopefully you figure it out.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
05-04-2019, 06:36 PM
Originally Posted by rskeans
Heh I'll have a video series about why I went the route I did
Thinking a stud finder is my best bet. If unlucky lags into the plywood will be my backup I think.
Opened up the antenna cover for the coax and was able to fish a string through so i think I'll take the roundabout route behind the TV to get to the batteries
05-04-2019, 09:19 PM
Retired Army Paratrooper
Don’t worry Brian, if you screw it up you can always just Flex Seal it. [emoji482]
Dennis & Zoleta
Retired US Army
2010 Grand Sport GT
05-04-2019, 09:25 PM
Dicor the whole roof!
05-04-2019, 09:46 PM
I put solar panels on my DX3 roof last summer, if you would like to talk I can pm you my phone number. Would be easier over the phone.
Larry
05-04-2019, 09:48 PM
05-04-2019, 09:54 PM
Originally Posted by Webefine
Looks like you did a very nice job.
05-05-2019, 06:18 AM
Larry
Thanks, but I think I've got a route figured out that's going to work. Appreciate it.
Let's catch up and compare notes at the rally.
05-05-2019, 07:49 AM
Not going to be able to make the rally this year, to many other commitments.
How many watts are you doing, I did 400
05-05-2019, 07:52 AM
I glued my panels on the roof! I couldn’t bring myself to putting screws in the roof.
05-05-2019, 09:42 AM
Looks you have room for one more skylight. Ha ha
2017 Puma 297RLSS
05-05-2019, 10:27 AM
Going with 600 on the roof and another 400 on the trailer. Frame for my first set of 3 is screwed and dicored. It's as stressful as I was afraid of lol.
I'm videoing the whole install so will share when it's ready.
Sorry well miss you at the rally!
05-05-2019, 12:50 PM
Well I confirmed my original question - yes the utility pedestal comes up into the front cap. I had drilled as far out and back from the wall but didn't see a drill bit. Fed some allthread up there and could feel it tapping on the underside of the front cap.
So I also confirmed the existing route the coax takes into the cap is the best way to go. I cut a new hole about 6" to the left of the coax hole and fished a wire to get my string over there. Then I pulled two 2AWG from the cab up to the roof. Wouldn't say it pulled easy, but wouldn't say it was hard either. Fished the 2AWG behind the TV no problem then used a wire to fish it behind the drivers cabinet into he pedestal.
Just have to go through the floor and I'll be into the battery compartment
05-07-2019, 04:27 AM
I'm with Aaron, there is NO WAY I'm drilling into my roof. One of my friends had a simple CB radio antenna installed in his Newmar and while it was repaired "several" times, almost the entire ceiling had to be replaced.
When he sold it and downgraded to a fifth wheel, the dealer drilled a hole in the ceiling (I forget why) and the first time it rained, it leaked.
You'd think that it's a simple matter of just sealing a hole but for some reason...
Of course, I'm sure you'll be just fine.
Mark
05-08-2019, 09:19 AM
And here's a pic actually depicting this
05-09-2019, 06:24 AM
And put back together. Yes I know my dicor work leaves something to be desired
