Grey tank leaking - need help
So I just took delivery of Isata 3 FW two weeks ago. During PDI - both tanks were filled & no evident leaks. Fast forward- now that it is home I have been 'camping' in the driveway & there is a leak in the grey tank - where the outlet pipe & the tank body meet. This is all one molded piece of plastic - so I am looking for any help on the situation. My dealership is 2+ hours away & I would like a DIY fix on the issue.
Once the water level hits the leak/pipe break - the water drip turns into a steady 'run'. So basically the tank level doesn't get past 1/3 full & the leak starts. This has me concerned because it is one molded piece collectively & I am wondering what is the best approach?
What type of glue should I use? ABS?
Any help is greatly appreciated!
2019 Isata 3 FW
