Old 05-19-2018, 10:13 PM   #1
retired18whler's Avatar
Has anyone replaced their dash XITESOLUTIONS?
Our 2015 DX3 in dash radio/nav/cameras unit XSG2NA-X2 hasnít worked well since we got the unit. Now the only things I use it for is when turn signals used the cameras come on... sporadically. It needs replaced and I donít know if I should replace with the same unit or is there a better one that works the same way?
retired18whler is offline   Reply With Quote
Old 05-20-2018, 07:30 AM   #2
There is a firmware update for the unit. Might want to try that first plus update nav map software.
jnlegran is offline   Reply With Quote
Old 05-20-2018, 09:35 AM   #3
shultz01's Avatar
Yes. I replaced with Kenwood DDX9704S and added the front camera. I use the iPhone and Apple Carplay for navigation.
Andy & Debbie Shultz
Harrisburg, PA
2018 Force HD 37TS
shultz01 is offline   Reply With Quote
Old 05-20-2018, 07:25 PM   #4
halla's Avatar
Same as Shultz, same Kenwood, added dash cam and love the Apple CarPlay.
2018 Dynamax Force HD BH---Just Rite-2
halla is offline   Reply With Quote
Old 05-20-2018, 08:07 PM   #5
Thanks to all of you for the information, Iím look into it this week.
Old 05-21-2018, 08:56 AM   #6
GM
bclemens's Avatar
You gonna be at the rally?
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 05-21-2018, 09:10 AM   #7
No, we are not able to squeeze the rally in between enjoying trips with our kids and grandkids.
Old 05-23-2018, 09:12 PM   #8
Final update as to dash radio, I bought and installed the Pioneer NEX
AVH-2240NEX. The new radio works with both Apple and Android. The mapping system I use (Android) can be displayed on the screen which is easier than looking at my phone.
My factory radio had an issue,; I believe hardware, also the camera problem I was having was the CONNEXX CVS300-01 was only seeing 5 to 6 volts instead of the 12 to 13 it needed. After fixing that, the system works as it should. I did read on the web because the CMM port on the CONNEXX box has nowhere to feed on the new Jensen radio that the trigger output would not function properly but this was not the case with mine. The CONNEXX box sends 12 volt thru the trigger to the radio. My new radio trigger will accept either battery or ground in the settings. You can buy a CONNEXX CVS150-01 that does not have the CMM port. I have one coming I will keep as a spare.
( by the way on our 2015 DX3 after tearing apart the front of the cab tracing wires- Iíll save you some trouble, the CONNEXX box is located on the passenger side above the door inside the compartment with a removable back.)
Thanks to all who responded, Greg
Old 05-23-2018, 09:46 PM   #9
thanks for sharing - many time we take our rv to places where we have no phone signal and count on a gps based nav system. What are your plans for that situation with the Pioneer?
Old 05-23-2018, 09:53 PM   #10
Itís called TamTam I use which is my wife and sheís great at reading her paper maps.
Weíre trying to teach our children and grandchildren how to read and use paper maps along with reading a analog clock or watch...finally we got our eldest granddaughter to be able to read her analog watch... ha ha.
