07-19-2018, 03:42 PM
#61
Commercial Member
Once I pulled up your VIN, I realized who you were. We have spoken before. You picked up your coach in January of 2017 from Copleys. You wanted tables with your coach, which we sent, but you did not think those adequate, so sent us prints of what you really wanted and I think we obliged.
If you have outstanding issues, Ive never been one to shy away. I have nothing to hide, only opportunities to get better.
PS. we canceled Copley's due to lack of service, so airing the dealer issues might not be relevant as they no longer have access to sell our product.
07-21-2018, 09:24 AM
#62
Originally Posted by Dick Skeers
I just figured out that the engine doesn't have to be running, just in the on position. i think that when turning the key to the on position i was turning past the on position and just going to the starting position.
I was reading this thread and just about to tell you this info, glad you discovered it. I have a 2019 I5 DS. The key must be on but the engine does not need to be running. Thing is as you know when you turn the key to the right with the RAM 'tip start' there is a fine line there from where the switch is 'on' and the 'start' portion is activated. But just 'on' is enough. Scott on another thread bought the upgrade firm ware and S/W kit so that he can control not only slides but also his leveling jacks with his phone app. Pretty cool.
Old Navy Chief
2019 Isata 5 36' DS 4x4
2015 Jeep Rubicon Toad
Days camped 2021 = 25
12-03-2018, 02:20 AM
#63
I have a 2017 Isata 3 FWS and with my battery reading 12.4 volts, I slide out the slide and the Slide panel gives me a red light saying lower power. It works fine with gennie on or with shore power? any thoughts.
12-03-2018, 08:46 AM
#64
12.4 is not that high. I always start my gennny or plug into shore power when moving my slide. Just not worth the chance of having a low voltage and screwing up the controller. Following this protocol, I have never had a slide issue.
2021 Isata 5 30FW
2022 Ford Ranger Tremor 4x4
(Previously owned a 2017 Isata 3 24FW)
12-03-2018, 08:48 AM
#65
Commercial Member
If its not giving you any issues then you should be fine.
The slide motor itself can draw the batteries down below...I think in the manual they say it needs at least 10.4v under load. Sometimes a bad battery, even reading 12.4 can drop below that when put under load.
If you're not having issues, I would continue to do what you are doing. Gen or engine running to help support the batteries.
12-03-2018, 11:35 AM
#66
I always use my generator or am plugged in when I operate the slide. When I first got my Isata 3, I tried using just the batteries. The warning light came on and I quickly stopped extending it. I would bring the slide back in, and then start the generator (and wait for it to 'kick' in and provide power)
, or plug in to land power if it was available. I can't operate the slide with the engine running. I wish I could. When boon-docking, it would be nice to have a backup to the generator. And the since the generator is noisier than the engine, I hate to have use the generator when we are leaving a campsite early or arriving late. Or have to use it outside the allowed operating hours at some campgrounds. I can operate the stabilizers, but not the slide, when the MB engine is running. If anyone knows of an easy fix to be able have the engine running when using the slide, thus enhancing coach battery operation, please let me know.
12-03-2018, 11:47 AM
#67
Hi, Brian Clemmons put out a diagram of the Battery Control circuit that allows the slide to run with the engine running. It is a very easy mod and allows exactly what you would like. If you do a search and read through previous threads you will find it.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Lab Buddy Biscuit Eater
USN-RET/DOD-RET
12-03-2018, 11:59 AM
#68
X2. After the re-wire, you can run the MB engine while operating the slide. All you need is to have the parking brake engaged.
2019 ISATA 3 FW
LiFePO4 Upgrade
2013 Honda CRV Toad
12-03-2018, 05:08 PM
#69
THANKS. Is this the link you reference?
http://www.forestriverforums.com/for...1&d=1531322946
12-03-2018, 05:10 PM
#70
That is exactly it and very easy.
2016 Jeep Willys JK
USN-RET/DOD-RET
