Old 06-11-2016, 10:04 PM   #11
ablarson's Avatar
I just cut the middle legs down 1.5" and it's much better. Not perfect but I think it's sleepable short term. Still slopes about 3" from the front to back and the bar underneath is uncomfortable but it will work until I figure something else out.
Newbie
2 RV Trips to date
19 States
2016 Dynamax Force HD
ablarson is offline   Reply With Quote
Old 06-13-2016, 09:35 AM   #12
GM
bclemens's Avatar
What two holes are you talking about? Is it in the carpet, picture 1?
As soon as I head from the supplier I'll let you know what their response was.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 06-14-2016, 08:20 PM   #13
Hey guys I discovered this issue back in Febuary and considered several options. I ended up having Dynamax send me the legs that were originally on the couch before being removed. The couch fits very securely and now works perfectly. The lack of legs on the furniture my also explain the dinette being lower than normal in relation to table. The easiest fix there is securing the latch before the table reaches full height. P. Werner
pwerner is offline   Reply With Quote
Old 06-14-2016, 10:22 PM   #14
ablarson's Avatar
Yes, picture one and two. There is a hole in each side. I looked under the slide out and it looks like there were carriage bolts in there at one time. I shot some silicone in there for now just to keep critters out.
Newbie
2 RV Trips to date
19 States
Old 06-15-2016, 09:38 AM   #15
GM
bclemens's Avatar
That is more than likely what they were. When we switched from ensemble (sofa dinette combined) to a separate sofa and dinette (for bigger sleeping area and more functional dinette), I think they had pre-drilled for seatbelt locations. Those ultimately ended up moving and they never filled them with a carriage bolt.
Old 06-26-2016, 09:34 AM   #16
viperdave's Avatar
any update yet from manufacturer? Can we get legs or any risers?
2016 Dynamax DX3
viperdave is offline   Reply With Quote
Old 06-26-2016, 01:22 PM   #17
I went through my dealer but I also called Dynamax and they would send the legs as well. It was an easy fix and now works great.
Old 06-27-2016, 07:44 AM   #18
GM
bclemens's Avatar
Well, the issue is our supplier no longer stocks sofa feet. I asked again what their solution was.
Old 06-27-2016, 05:47 PM   #19
Brian-would you happen to know the approximate length/height of the legs that would be attached to the sofa if not used in MH setup? I'm trying to figure out how high I need to raise the sofa to get the hide-a-bed laid out straight, and new L-brackets to try and use the same screw-holes. Thanks.
Mike
2016 Force HD
Mike
2016 Force HD 36
BLK-9 is offline   Reply With Quote
Old 06-29-2016, 03:13 PM   #20
GM
bclemens's Avatar
ok..here is what I got from the supplier.
Originally the sofa legs were about 3.75". This seemed to make the sofa bed flow downhill, made it difficult to secure the sofa to the floor and it sat too tall for shorter people. At some point, someone suggested taking those legs off to solve those issues...but as with any good deed, it did not go unpunished. That made the sofa sit low....which shorter people are just fine with...but when made into a bed, makes the bed slope towards the heads.
So, in a perfect world, they say tell me that 2" feet under the sofa is the way to go.
bed
