Old 06-09-2016, 05:58 PM   #1
ablarson's Avatar
Hide a bed
Hello, we are new and our 2016 Dynamax Force HD has a hide a bed. When we fold it out it doesn't lay flat. The part under the couch is slanted way downhill. Ideas of what I am doing wrong?
2016 Dynamax Force 37TS HD
ablarson is offline   Reply With Quote
Old 06-09-2016, 06:26 PM   #2
Ours does the same. The foldout brace-legs are too long by a couple of inches.
Mike
2016 Force HD
Mike
2016 Force HD 36
BLK-9 is offline   Reply With Quote
Old 06-09-2016, 07:52 PM   #3
viperdave's Avatar
just picked up a new 2016 DX3. My son is 6'3" and just didn't want to sleep in the bunk. Our hide a bed is exactly the same as you reported. I assumed the hide a bed would have a terrible mattress and be somewhat uncomfortable but did not think it would be COMPLETELY unusable. I thought that I was not folding it out incorrectly. Your head is a few inches below your hips then your feet somewhere between the two. Sleeping in a rainbow shape isn't too comfortable.
I've lurked on here for a month prior to picking up my DX3 and am very impressed by bclemens spending time on the forum. Hopefully he can explain if something is weird or can be adjusted. I can't believe with all of the thought put into all of the systems on this coach that the hide-a-bed passes as such. If that is the way it is then I'll look to have a fix fabricated.
viperdave is offline   Reply With Quote
Old 06-09-2016, 08:29 PM   #4
Not sure, but instead of fabricating fix to the brace-legs, I was thinking of 2-3 inch shims under the couch legs. Not sure if this is possible, but my grandchildren refuse to sleep on it given the 2-3 inch slope.
Mike
2016 Force HD
Mike
2016 Force HD 36
Old 06-09-2016, 09:23 PM   #5
GM
bclemens's Avatar
Pictures? My initial inclination is that the legs on the sofa are missing.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 06-09-2016, 09:47 PM   #6
ablarson's Avatar
I'll grab pictures tomorrow.
One other thing I noticed while I was looking under the head of the bed is that there are two holes large enough I can see daylight. They are close to the sides where the bed mounts on the inside of the couch. Looks like maybe someone forgot to mount something?
Again, I'll snap some pics tomorrow and post them up. Thanks!
Newbie
2 RV Trips to date
19 States
Old 06-10-2016, 08:06 AM   #7
ablarson's Avatar
Name:	ImageUploadedByForest River Forums1465563835.506798.jpg
ID:	110689Click image for larger version
Name:	ImageUploadedByForest River Forums1465563852.576290.jpg
ID:	110690Click image for larger version
Name:	ImageUploadedByForest River Forums1465563889.916581.jpg
ID:	110693Click image for larger version
Name:	ImageUploadedByForest River Forums1465563905.416552.jpg
ID:	110694Click image for larger version
Name:	ImageUploadedByForest River Forums1465563919.467781.jpg
ID:	110695Click image for larger version
Name:	ImageUploadedByForest River Forums1465563934.086122.jpg
ID:	110696Click image for larger version
Name:	ImageUploadedByForest River Forums1465563959.539581.jpg
Newbie
2 RV Trips to date
19 States
Old 06-10-2016, 08:54 AM   #8
GM
bclemens's Avatar
Easiest fix is to increase the angle of the end bar and cut down the middle bar.
The more difficult, would be to add feet to the sofa, but then you have to figure out a way to bolt the sofa back to the floor now that it is 2" higher.
I have a call into the supplier to see what they can offer up as a solution.
Old 06-10-2016, 07:40 PM   #9
viperdave's Avatar
great pictures! Mine is exactly the same. Thanks bc for checking to see what might have happened with that.
Old 06-10-2016, 11:20 PM   #10
ablarson's Avatar
Please let me know what they say. I was going to unbolt the bed from the sides of the couch and move it up a few inches but If there is a better fix I'm all ears. I thought about cutting down the middle bars also but would need to find a cap of some sort so the floor doesn't get damaged. If this was a used RV it wouldn't even be a question but having to cut down legs and make more holes in a brand new RV stings a little. Speaking of holes, any idea what the two under the couch are?
Thanks for your help Brian.
Newbie
2 RV Trips to date
19 States
bed
